Author Topic: no heat to footwells  (Read 2218 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« on: 05 November 2011, 15:33:16 »
Good afternoon all,i know this has been asked before.But can someone point me in the right direction.No heat at all going to the foot-wells,1995 3ltr elite manual dials.Every where else lovely and warm :).All help apreciated Dean :y
moggy
  • hartlepool
Re: no heat to footwells
« Reply #1 on: 06 November 2011, 10:40:28 »
Thanks for the help and advice :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 06 November 2011, 10:56:56 »
Have a look under the dash where your feet go and see if you have pulled out a vacuum pipe.
Have you had any work done under the bonnet reciently ?
The more details, the better on the problems  ;)
moggy
  • hartlepool
« Reply #3 on: 06 November 2011, 15:44:02 »
Hi tigers,no work done recently.I did not know there were any vac pipes under there,also no heat from passenger side either.Its just with winter coming it would be nice to sort it,BTW thanks for the reply :y.Deano
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 06 November 2011, 19:04:13 »
When you turn the dial to re direct the warm air, can you hear a hiss from behind the dash ?
The reason I ask is I replaced my radio 2 years ago.
I had a bit of trouble getting the wiring loom back behind the radio and pulled one of the vacuum pipes of the back of the controls  :-[
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #5 on: 07 November 2011, 03:29:53 »
if you leave engine to get up to temp with out driving see if it works then if it dose you will need to clean out the systerm has done it on mine so meany times. need to back flush from main pipes to get all the muck out. when out the water will be red then white. after it gose white get some boiling water and kettle cleaner poor the kettle cleaner into the kettle and put it into the rad top pipe when water comes out other hole plug it up and leave for an hour then flush out may take 2 gose at it, if still red water repeat till clean. did that on mine 3years ago and had no problems still works fine now.
Solar charger fitted.
If not Broke dont fix it..
moggy
  • hartlepool
« Reply #6 on: 07 November 2011, 18:35:28 »
Hi tigers,no noticeable hiss.But about 6 moths ago me and chris db changed the hbv,any connection do you think :y
moggy
  • hartlepool
« Reply #7 on: 07 November 2011, 18:39:47 »
Hi freecall,not tried this up to temp thing.I will try that,but if it doesn't any other ideas :y.Dean
freecall666
« Reply #8 on: 08 November 2011, 01:14:41 »
there is another thing check the pollen filter if its not been changed from new then it could of fell in or brocken up and gone in to the air intack that would stop air flow, had a few leaves in mine, was funny when they went all bits came out of the air vents. but would say the back clean etc should sort it out. :y, air intack filter is on pass side engine bay take rubber trim off and lift the flap that the rubber keeps it closed, to remove clips for filter left side hld lip in middle and pull to left out, same on right pull to right out...
moggy
  • hartlepool
« Reply #9 on: 08 November 2011, 07:07:26 »
Hi freecall,changed the pollen filter about 9 months ago.But i will have a look thanks Dean :y
freecall666
« Reply #10 on: 10 November 2011, 02:46:17 »
it it fixed now? :y
