Author Topic: Face lift locking door pin rattle.  (Read 3196 times)
« on: 06 November 2011, 08:56:11 »
TB decided to do something about his, and visited the dealers. Seems the plastic pin surround that is set into the door card is available separately in various parts. Some cheap, some very expensive.
But the important part, the bit with the felt insert in is quite cheap, couple of quid. But what I found interesting was the felt bit that's supposed to stop the rattle is held in by a clip insert.
I wonder if removing the surround from the door card, unclipping the felt bit, roughing up the felt and re seating it, possibly rotated 90 degrees, would stop the rattle? For a good while anyway...?
Not a massive issue on the facelift....  But it is annoying. >:(    ;D
Re: Face lift locking door pin rattle.
« Reply #1 on: 06 November 2011, 09:00:18 »
These bits. Felt piece under thumb, as it was windy.
« Reply #2 on: 06 November 2011, 09:32:17 »
Its odd, out of all 4 facelifts we have I can't say I've really experienced it  :-\
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #3 on: 06 November 2011, 09:40:23 »
Would be nice to fix, it's the only rattle I have in my car.
But it's only really noticeable when the stereo is turned up and it starts to vibrate the pin.
Budget tyres, false economy.
« Reply #4 on: 06 November 2011, 10:29:06 »
The bit that needs changing is quite cheap. The clip in the bag under chrisgixer's hand...  ...well, FFS don't break it, it's over £20 ex vat :o
« Reply #5 on: 06 November 2011, 10:30:55 »
Gayboy, if you want to be ginuea pig, you are welcome to the old one. But if you break the clip that holds it in place, that's £20.45 + VAT ;D
« Reply #6 on: 06 November 2011, 10:32:21 »
I've only owned 2 facelifts, both have suffered
« Reply #7 on: 06 November 2011, 10:53:46 »
Arent the (later ?) square topped pins said to be less prone to rattling ?  :-\
« Reply #8 on: 06 November 2011, 11:10:09 »
Aren't all facelift pins the same   :-\
« Reply #9 on: 06 November 2011, 11:12:38 »
Mine are tapered towards the top.My 2002 breaker had square topped ones.Vaguely remember someone saying the square ones were less prone to rattling. :-\
« Reply #10 on: 06 November 2011, 11:15:02 »
My 2000 facelift and my 2003 facelift both had rattly pins...
« Reply #11 on: 06 November 2011, 11:15:33 »
And its not the pin thats at fault, its the surround it sits in...
« Reply #12 on: 06 November 2011, 11:33:49 »
Both my face lifts had trouble. Used to be better locked, now better unlocked... But very irritating.
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #13 on: 06 November 2011, 12:24:29 »
if it's the felt that's the issue, surely it's be fairly easy to make something to either  replace it.... or thicken it up .
(i foresee a bunch of people raiding their kid's fuzzy felt sets for a bit of felt to cut to shape....  )
« Reply #14 on: 06 November 2011, 13:59:46 »
Mine rattles like a bstard ::) The door cards are from an early facelift and were modified using the trim pieces from the original later doorcards.
I didn't notice the felt piece, where exactly does that go? :-\
Best solution I could come up with was to tension the lock rod with an elastic band, just loop it through itself around the rod where it goes through the membrane and  refit the upper screw on the trailing edge of thedoorcard so that it goes through the spare end of the band.  :y
Whilst I appreciate that it is a bit 'Heath Robinson', it does seem to work. I just need to sort the front passenger door one as that is the loudest noise inside the car. :-\
Page created in 0.028 seconds with 21 queries.
