wanted heated seat switch (front) for 1996 3.0 elite
Started by doug4293, 07 November 2011, 01:46:02
doug4293
my switch popped the fuse, and now it only works if its pushed in and held in, looking for a new switch if anyone has one ?
Signature deleted as it's too big.
sjc
Got a mini-facelift one here - they're interchangeable, you just swap the front cover over to keep it matching the rest of your switches (that's assuming you have the hard plastic faced ones, not the later rubbery ones that go all worn).
BTW, I know for sure it works cos that's what I've done on mine.
Say £5 posted?
MutantCav
I've got one you can have for the price of the postage ;)
doug4293
my next question is how do you remove the switch ? plain screwdriver into the top of the switch and withdraw it ?
sjc
Use a 4-5mm flat screwdriver at the bottom of the switch - put a little piece of card underneath it to protect the fascia - and lever it out, should be a little resistance at first then it will just pop out.
