Wanted Radiator 3.2
Started by JamesV6CDX, 08 November 2011, 14:07:02
Rad needed for 3.2 V6 Auto. My cooler for gearbox is is seperate to the rad and sits in front of it, so must be compatible with this. Paypal at the ready  :y
TBH, I'd suggest new James... Sub £100 :y :y You may get one shipped with the GB cooler in it but it doesn't matter, just leave those 2 connections open ;) ;)
Quote from: Lazydocker on 08 November 2011, 21:30:39
6
That's not too bad, actually! :y
Apart from the internal GB cooler, what's the difference  between a 2.5/3.0 V6 rad, and the 2.6/3.2?
Cheers :)
James
Quote from: JamesV6CDX on 08 November 2011, 21:32:54
6
Cheers :)
James
Nowt ;) You may find you need to modify one of the (inner) fan mounts so it sits properly though :y
Order This One and tell them that you know it's listed for a manual and yours shows as an Auto, but that's the one you need ;) ;) :y :y
Cheers LD, v much appreciated :y :y
ngrainqey
i think i've still got a couple of radiators manual and auto you can have if you want for cost of postage? i can double check that i've still got them and pm you unless you need it urgent?
thanks
alex
V8!!!!
Hi Alex,
On the basis I need to spend on new GM camcover gaskets, and other bits for MOT, that would tide me over quite nicely!!
If you could have a look, I would really apprecaite it :y
Cheers,
James
ngrainqey
ok james :) i'll have a look for you tomorrow and then pm you  :y
alex
V8!!!!
Quote from: ngrainqey on 08 November 2011, 22:39:36
alex
:y Thanks ever so much :y
