Author Topic: Plastic side skirt clips  (Read 1767 times)
« on: 08 November 2011, 18:56:49 »
I've got some new clips to go on first, how do these actually attach to the car?  :-\
Some of them are currently broken
Re: Plastic side skirt clips
« Reply #1 on: 08 November 2011, 19:27:03 »
ok, figured that out, actually very easy. The end clip though, has a black plastic flap thing, is that supposed to be there or left from previous skirt?
twiglet
  • Norwich, Norfolk
« Reply #2 on: 08 November 2011, 19:29:38 »
That's from the previous skirt Mark.  All the clips should be the same.  :y
« Reply #3 on: 08 November 2011, 19:30:26 »
Thought so, but decided to post up before snapping it off.
I'll use a spare clip on it.
Thanks  :y
twiglet
  • Norwich, Norfolk
« Reply #4 on: 08 November 2011, 19:33:40 »
If you slide the black bit horizontally towards either the front or rear of the car, it should come out easily, leaving the white clip in tact.  :y
« Reply #5 on: 08 November 2011, 19:50:30 »
All done, this car used to have Irmscher body kit, something was odd it would not come out. Had some spare clips (Thanks Chris!)
So just snapped it off, behind the clip was some gunk, had to get a chisle, wack it and it came off so the clip would sit flush.
All back together now.
Also changed air filter while I was there, couple of nice little jobs sorted  :)
Cheers for the help  :y
« Reply #6 on: 08 November 2011, 20:06:52 »
Yeah somebody has tried to glue it back together. Glue holding the piece of old side skirt in.
twiglet
  • Norwich, Norfolk
« Reply #7 on: 08 November 2011, 20:10:32 »
Does that mean mean that someone is going to have a slightly 'flappy' Irmscher side skirt?  :-X
« Reply #8 on: 08 November 2011, 20:20:33 »
Nah, it's only one lug of two per clip.
« Reply #9 on: 08 November 2011, 20:22:49 »
Surprised how easy it went on, just lined it up, quick wack, clipped on pushed on further along, then quick wack at each clip point.
Although i am missing the two screws for the end plate  :(
« Reply #10 on: 08 November 2011, 21:08:14 »
Not screws, those expanding clips. And they were in the holes they go in...
« Reply #11 on: 08 November 2011, 21:08:57 »
Now have you got a new battery yet...  ...I may need mine back fairly soon  :-X
« Reply #12 on: 08 November 2011, 21:34:39 »
Ordered, are you going by the dealer on Saturday morning?  ::)
« Reply #13 on: 08 November 2011, 21:39:11 »
Nope, won't have time.
« Reply #14 on: 08 November 2011, 21:40:11 »
Hope its there by Thursday then  :(
