Pages: 1 2 [3]  All   Go Down
Author Topic: Microwave help.  (Read 5337 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Microwave help.
« Reply #30 on: 09 November 2011, 19:39:25 »
forget getting a new microwave; simply make sure you have all the take away menus for your area  :y
RIP Paul Lovejoy
Re: Microwave help.
« Reply #31 on: 09 November 2011, 19:41:22 »
I must be braver than you as well then  ;D I've had mine in bits several times......all perfectly safe if its not plugged in;) ;D ;D
Not like CRTs, then.. every belt I've had from them, they've been unplugged (sometimes for a while) ;)
So they can give you a pisser even when disconnected?..... :o :o
You can get a much bigger belt off an unplugged microwave.
But, to be quite honest, if the microwave bit has not been used for a while it will be ok.
You will find inside a diode, a large metal capacitor and potentialy also a HT fuse.
A visual inspection is a good start, just visualy look at the cap and see if there are any bulges, dents or splits.
Re: Microwave help.
« Reply #32 on: 09 November 2011, 22:03:19 »
You tight wad, nothing has changed has it, 10 years use of you being poorly misused by the gorgeous mrs opti just cos you have to cook your own ding ding meals 3 times a day.  :-\
I remeber the days when you made mrs opti go with out a new washing machine,  . . . . . I really thought you had changed.  :-X
ps, if you are a bit short and they have a whip round for you then I have a bit of shrapnel I am willing to throw in.  ::)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: Microwave help.
« Reply #33 on: 09 November 2011, 23:53:43 »
Almost Christmas, so put it at the top of Mrs Opti's Christmas presents list and then make a hasty retreat.  :y ;D ;D ;D
Re: Microwave help.
« Reply #34 on: 09 November 2011, 23:59:54 »
or even a tasty reheat.
Rods2
Re: Microwave help.
« Reply #35 on: 10 November 2011, 00:01:09 »
 ;D ;D ;D ;D
Rods2
Re: Microwave help.
« Reply #36 on: 10 November 2011, 00:11:31 »
Opti, safety first, when working on HT electronics ALWAYS only use one hand, best to put the other in your pocket as a few kV, hand to hand via the heart is very bad news.  :'( :'( :'(
During my electronics apprenticeship I never had to touch HT equipment but a friend who worked in a TV shop said that was how they were taught to repair TV's, because of the dangers of charged HT capacitors.
Re: Microwave help.
« Reply #37 on: 10 November 2011, 00:19:55 »
A TV HT supply will make you jump,but can't deliver lethal current.
TBH, with this sort of device, it's a case of never operating it without the case on, and discharging the capacitor before you touch anything. To be frank, a shock from this will kill you, 100% certainty, hand in pocket or not.
It's a very simple circuit. All components can be tested and the fault found without working on it powered-up so it's simply not worth the risk of doing so.
Debs.
Re: Microwave help.
« Reply #38 on: 10 November 2011, 10:11:35 »
Forget the ping meals...... ::)
.....do something REALLY fun with that old radar-oven! :y
http://www.capturedlightning.org/hot-streamer/lulabs/Tesla.html
Re: Microwave help.
« Reply #39 on: 10 November 2011, 10:47:56 »
Ummm. :-X
Re: Microwave help.
« Reply #40 on: 10 November 2011, 10:55:39 »
Ummm. :-X
You've got one at home, haven't you...
Re: Microwave help.
« Reply #41 on: 10 November 2011, 11:06:59 »
Ummm. :-X
I'd be lying if I said the though hadn't crossed my mind but, alas, no.
Re: Microwave help.
« Reply #42 on: 10 November 2011, 20:09:30 »
Better than Viagra so I've heard!  ;)
Pages: 1 2 [3]  All   Go Up
