Author Topic: engine miss fire and gearbox check light on  (Read 1855 times)
robmac
« on: 09 November 2011, 19:41:19 »
got a missfire at 3300 revs along with gearbox checklight and engine check light today. car is a facelift 2.5 v6 auto.year 00.
wont rev past 3300 revs but runs fine below that. once the miss fire occurs the gearbox goes into limp mode. turn off ignition and fault light goes out untill missfire occurs again.
any takers???
Re: engine miss fire and gearbox check light on
« Reply #1 on: 09 November 2011, 19:42:58 »
gearbox check light? no such thing?
I'd be checking plugs for oil / water as a starter  :y
robmac
« Reply #2 on: 09 November 2011, 19:44:32 »
there is actually on the multi function display.. gearbox displayed and check light is lit bottom left.
« Reply #3 on: 09 November 2011, 19:46:33 »
ohhh, thats not good then!
Sounds like you've got another fault here, causing the gearbox to go into limp mode.  :-\
robmac
« Reply #4 on: 09 November 2011, 19:47:58 »
thats what i was thinking....i understand the gearbox check light can come up in other faults but not sure what?
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #5 on: 09 November 2011, 19:54:17 »
When I occasionally got this gearbox fault and it going into limp mode it was the crankshaft sensor. It got worse with the engine cutting out when it got hot.
« Reply #6 on: 09 November 2011, 19:58:00 »
Is on TID equipped cars
OP - Paperclip the engine, lets start with the easy stuff ;D
robmac
« Reply #7 on: 11 November 2011, 12:52:49 »
op com shows fault code 19.incorrect rpm signal?
« Reply #8 on: 11 November 2011, 13:01:34 »
Failing crank sensor
robmac
« Reply #9 on: 11 November 2011, 13:09:14 »
ok, thanks for that..better get one then before it dies completely. thanks for help as usual. :y
robmac
« Reply #10 on: 15 November 2011, 13:44:59 »
new crank sensor fitted and all ok now. thanks  :y
