Pages: 1 2 [3]  All   Go Down
Author Topic: Changing 2.5 V6 ECU temp-sender?  (Read 4899 times)
Re: Changing 2.5 V6 ECU temp-sender?
« Reply #30 on: 20 November 2011, 20:12:00 »
Debs, have you a laptop with a 'real' serial port?
Debs.
« Reply #31 on: 20 November 2011, 20:44:56 »
Sadly not.......it`s just VGA and USB. :-[
'Idle' wondering: would a long period of battery disconnection, reset the trims?.......Don`t worry if not, I can easily wait `till the meet for your 'OOFicial' analysis! ;)
« Reply #32 on: 21 November 2011, 08:32:09 »
Some bits reset, not sure if its those....still only a few days off.
Ill see if I can get you a way of keeping an eye on them :y
May have an old device I can make work.....never been easy without serial though.
« Reply #33 on: 21 November 2011, 09:00:47 »
Have the throttle butterflies been checked and the idle valve been given a real good soak and clean yet?
Debs.
« Reply #34 on: 21 November 2011, 09:51:02 »
 :y Yes, thoroughly soaked the idle valve..... and used a can of carb-cleaner (w/tooth-brush) to clean the butterflies/throttle-body; they were secure on the cross shaft, closed in synchrony and tightly held carb-cleaning fluid in the vestibule fluid when closed.
.....on a cold/cool engine; when the idle is 'flicking' (sorry, can`t think of another way of describing it; other than by what the tacho-needle is registering): RPM is first, well-above, then back down to the expected idle {for that engine temperature}, I`m surprised at how fast the engine revs are changing at that time, in fact, I`d struggle to replicate such rapidity of an RPM change using the pedal. :-\
« Last Edit: 21 November 2011, 09:53:11 by Debs. »
« Reply #35 on: 21 November 2011, 09:52:33 »
Debs.
« Reply #36 on: 21 November 2011, 09:56:40 »
'flicking'
Hunting?
 :-\ I`d have thought that hunting would be a more leisurely change of RPM around a fixed point....this is a very rapid variation. ;)
« Reply #37 on: 21 November 2011, 10:37:31 »
When you soaked the idle valve, did you also use a screwdriver (carefuly) to actuate the butterfly plenty of times?
A small artists paint brush is also very good for tickling the dirty bits with.  ;D
Debs.
« Reply #38 on: 21 November 2011, 10:52:31 »
 :o Ooooh, matron! ;D
Pages: 1 2 [3]  All   Go Up
