Author Topic: Check control module - Where is it?  (Read 4825 times)
« on: 10 November 2011, 20:23:23 »
As above really :y
Would it be advisable to get the MID, module, and stalk from the same car? :-\
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Check control module - Where is it?
« Reply #1 on: 11 November 2011, 02:35:32 »
same for same, whats wrong with mid?
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 11 November 2011, 11:38:58 »
It's a tid ;)
  • Auckland
    • Mazda MPV
« Reply #3 on: 11 November 2011, 21:19:13 »
How does the lamp check work?
I am fairly certain that the full current to the lamps does not pass through the TID/MID/GID/CID because the pins on the grey plug look too small to me to carry the current.
Is there a dedicated lamp check module somewhere?
« Reply #4 on: 11 November 2011, 22:39:48 »
Yep
  • Auckland
    • Mazda MPV
« Reply #5 on: 11 November 2011, 22:49:39 »
Yep
Hmmm. Haynes says "P25 Bulb failure sensor".
The diagram is too small to read without assistance  :( if I can find some reading glasses  ::) I want to see how many wires link it to the check control (TID/MID/GID/CID)
« Reply #6 on: 11 November 2011, 22:51:09 »
Module is up behind pass. glovebox
  • Auckland
    • Mazda MPV
« Reply #7 on: 11 November 2011, 23:20:58 »
Yep
3 wires.
« Reply #8 on: 11 November 2011, 23:25:57 »
Cheers Rob :y Is it bolted to the A post :-\ or is it buried behind the heater gubbins? :-\
Yep
Thanks Andy :y If worse comes to it, I can try and play follow the wires... ::)
« Reply #9 on: 12 November 2011, 14:44:45 »
Yep
Glovebox out jobbie
« Reply #10 on: 13 November 2011, 18:13:43 »
Oh joy ::)
