Author Topic: What size LPG pipe to use ?  (Read 1037 times)
Ken T
  • Stockport
« on: 10 November 2011, 20:44:39 »
I am just compiling a shopping list of bits to finish my LPG instal, and have a query. My Reducer is a V-SGI with an 8mm inlet, the tank I was looking at has a Tomassete multivalve with an 8mm inlet and 6mm outlet. What is the best pipe to use for the main run, 6mm or 8mm ?.
Ken
Re: What size LPG pipe to use ?
« Reply #1 on: 10 November 2011, 21:16:04 »
If this is for a V6 then you really need 8mm feed pipe to make sure you can get sufficient fuel through ;)
Which means you need a 8mm feed on the multivalve too
Ken T
  • Stockport
« Reply #2 on: 10 November 2011, 21:43:48 »
Thanks Paul,
looks like I got to do more research into which multivalve to get. They don't seem to publish inlet /outlet sizes for these, so I'll have to call Tinley in the morning and see if he got any.
Its only a small V6  ;D ;D ;D
Ken
« Reply #3 on: 10 November 2011, 21:56:37 »
Thanks Paul,
Ken
You might get away with 6mm but I wouldn't want to risk it ;)
ISTR That Tomassetto ones have an 8mm outlet :-\ :-\
Ken T
  • Stockport
« Reply #4 on: 10 November 2011, 22:05:01 »
I called Tinley today and that's what  he said, maybe cause I hadn't specified the tank size I was after he gave a small one.
I want to get this install finished asap, fed up putting in a fortune in petrol every week. :-X Got any cheap petrol ?.  ;D ;D ;D
Ken
