Author Topic: Is my alternator goosed?  (Read 1530 times)
Malcolm_D
  • York
  • It shines!
« on: 10 November 2011, 21:15:24 »
2002 2.6 Elite. On the way home, car running fine when the battery warning light comes on, still running fine. After a while the display begins to dim and the ABS / TC lights come on, I continue to drive but turn everything electrical off, instruments stop working the engine and steering start to feel sluggish, other lights come on including the engine management light. I got home turned the engine off, tried to start it - nothing. Voltage at the battery reads 9.8v. After a couple of hours on charge the battery shows 12.3v, engine starts and all the lights are out apart from the battery light. Checked voltage at battery with the engine running - 9.8v  :(
Alternator goosed? If it is what is the best advice for replacement?
Re: Is my alternator goosed?
« Reply #1 on: 10 November 2011, 21:19:48 »
Follow Kevin Wood's Maintenece Guide :y
Malcolm_D
  • York
  • It shines!
« Reply #2 on: 10 November 2011, 21:25:04 »
Just found it and had a quick read, that's my weekend sorted then. ;)
Elliott19864
  • Tyne & Wear
    • Omega 2.5 v6 GLS
« Reply #3 on: 11 November 2011, 00:05:53 »
Definetly alternator, battery should read over 12 volts with the engine running.
Malcolm_D
  • York
  • It shines!
« Reply #4 on: 13 November 2011, 23:48:02 »
Never got round to it this weekend, had to sort SWMBO's Volvo for the mot. ::)
When I get round to it this week should I believe the Haynes book and remove the alternator from underneath or do the OOF experts have wiser advice?  ;)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 14 November 2011, 07:55:56 »
MarksDTM has written a guide on reconditioning the alternator, if that's any help.
I like red cars
Malcolm_D
  • York
  • It shines!
« Reply #6 on: 20 November 2011, 23:25:48 »
Got the old one off, pig of a job getting to the back of the top bolt, in the end I held the torx head with an 11mm ring spanner as i couldn't get a ratchet and torx socket in! Cleaned the bottom of the block and surrounding area while it was accessible, new alternator fitted (£90 through a mate in the trade). Now working as it should - I'm happy.  :)
