Author Topic: can anyone help with my problems with omega 2001 2.6 v6  (Read 8477 times)
Re: can anyone help with my problems with omega 2001 2.6 v6
« Reply #30 on: 13 November 2011, 22:41:24 »
One way of finding air leaks is to spray LIGHTLY with carb cleaner whilst the engine is running, spray lightly along vac pipes, plenum base, generally all around the engine..... but in a controlled manner .. don't just swamp the compartment.....  when the engine note changes it means some vac cleaner has been sucked in and burned as unmetered fuel, hence the change in engine note.
Closer examination of that area will eventually pinpoint the leak. Fix the leak, wipe the engine down with papertowel .. Voila .. fixed problem and a nice clean engine
Bit difficult that - ops car won't start  ???
Someone suggested MAF maybe - just unplug it and try again - if it starts then dodgy maf.  to find maf follow trunking down from air filter front drivers side - its the first plug you come to.
Agree probably crank sensor - its around £50 from Vx on TC - easy to replace - believe there's a howto  :y
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #31 on: 14 November 2011, 12:43:58 »
pulled out maf semsor d plugged back in still wont start
stuck between changing fuel pump ad fuel filter or crank shaft sensor first
thanks :y
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #32 on: 14 November 2011, 12:45:47 »
bloody battery now dead aswell
so cant do pedal trick arhhhhhhhhhhhhh
« Reply #33 on: 14 November 2011, 19:21:32 »
RIGHT
before doing anything else, read the codes.  Pissing around like this has stored more codes, masking, potentially, the real fault.
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #34 on: 14 November 2011, 19:40:25 »
going to get battery charged in morning and do the pedal trick
and take it from there
will post codes on and hopefully someone can help
thanks all
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #35 on: 15 November 2011, 10:05:27 »
got fault code only code comming up is 1530
got car started but alot of white smoke comiing out is that just because it has been lying for about 6 weeks and not starting
thanks
« Reply #36 on: 15 November 2011, 10:24:02 »
P1530 is an AC relay issue so not likely to be related
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #37 on: 15 November 2011, 22:32:42 »
well did getcar started earlier let it run for about 2 or 3 hours was driving great got back turned it off came back out 5 mins later not starting again arhhhhhhhhhhhhhh
just done pedal trick and it now reads 2 codes the 1530 as it did earlier now has 0335 aswell
and still wont start
any help apreciated
thanks :y
« Reply #38 on: 15 November 2011, 22:35:37 »
0335 = Crank sensor .... the one item that stops the V6 dead ... easy enough to change ..
http://www.omegaowners.com/forum/index.php?topic=90540.0
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #39 on: 15 November 2011, 22:38:12 »
well i geuss you guys are defaatly worth asking as you were right
just read code 0335 is cranshaft sensor position a circuit malfunction
now a do take it that means its gubbed and needs replaced the only other thing is there more than 1 of these crankshaft sensors
just wondering as it says position a
cheers
« Reply #40 on: 15 November 2011, 22:42:14 »
There is only one crank sensor on the omega V6 .. the OBDII list of codes is standardised for all vehicles and some have more than one.
As you are DBW with the 2.6 there is (I believe) only 1 CS that fits so a dealer will have no problem supplying the right part.
Genuine VX only .. no pattern parts or you'll be changing it again next month. Follow the guide and re-route the cable as instructed.
Takes less than 30 minute and only tools needed are a torx driver, snips and cable ties.
« Reply #41 on: 15 November 2011, 22:42:50 »
2.6/3.0/3.2 90540743 around £50 on TC
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #42 on: 15 November 2011, 22:51:39 »
whats tc mate sorry not up with the lingo yet lol
thanks for the help rob
was going to buy a fuel filter till u said just do pedal trick
so cheers mate :y
« Reply #43 on: 15 November 2011, 23:00:04 »
jamescdxv6
  • glasgow
    • 2001 omega 2.6 v6
« Reply #44 on: 15 November 2011, 23:05:14 »
cheers andy :y
