Author Topic: 2.5 V6 engine fault update  (Read 1410 times)
Peterbos
  • Somerset
« on: 15 November 2011, 12:15:15 »
More help please.
First a brief diary of event so far.
Aux belt tensioner failed and took out the belt. These items were replaced. (the engine did boil up but only lost 2 pints of coolant)
Engine started fine but cut when it got to temp. Leave for 5 mins restart ok then cut and so on.
Suspect crank sensor now replaced.
Engine started ran for 1 min or so and cutout and now will not fire at all.
Paperclip test shows 73 mass air sensor voltage low.
I've checked all the pipework around area where I was working when replacing the belt and can fine nothing obvious. All pipes and rubber conectors appear ok and there is nothing I can see hanging. All the plugs are conected. All the larger pipe clips are tight.
Any ideas would be appreciated.
Thanks Pete  :-\
British by birth
English by the grace of god !
Re: 2.5 V6 engine fault update
« Reply #1 on: 15 November 2011, 13:01:09 »
V6 will start with a MAF disconnected, any other codes?
Also, not sure why a snapped auxbelt would cause you to loose coolant? It will stop the water pump turning, but it should not create a leak.
« Reply #2 on: 15 November 2011, 13:04:36 »
More help please.
Suspect crank sensor now replaced.Engine started ran for 1 min or so and cutout and now will not fire at all.
Thanks Pete  :-\
Genuine?
« Reply #3 on: 15 November 2011, 13:16:18 »
It will if you ignore it for long enough. No water pump = no coolant through the radiator = no heat transfer = gets very hot = it boils over & spews coolant through the relief valve in the header tank = loss of coolant  ;) ;)
« Reply #4 on: 15 November 2011, 13:19:09 »
Good point, did not think of that. But loosing 2 pints is going some!
Peterbos
  • Somerset
« Reply #5 on: 15 November 2011, 16:05:33 »
The coolant loss was thro the header tank filler cap and yes genuine sensor.
British by birth
« Reply #6 on: 15 November 2011, 16:23:27 »
When it actually runs, does it run on all 6?
I sent you a PM yesterday... :y
Peterbos
  • Somerset
« Reply #7 on: 16 November 2011, 00:45:58 »
Fired up second or third piston up and ran sweet as a nut for around a minute then just cut out and died.
British by birth
