Author Topic: Eberspaecher D3WZ  (Read 5385 times)
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
Eberspaecher D3WZ
« on: 16 November 2011, 22:20:50 »
Is there anyone here who has a maintenance manual for an auxiliary heating Eberspaecher D3WZ?
I this system in my Omega but doubt if it works.
What I've found on the Internet is a manual for a VW T4 but not for the omega.
Engine type is Y2.5DTi 2003.
Gr Jack
Re: Eberspaecher D3WZ
« Reply #1 on: 17 November 2011, 13:02:26 »
That engine was never fitted to UK Omegas. Might be better posting this of a BMW 5 forum :)
« Reply #2 on: 17 November 2011, 13:22:41 »
but the Eberspaecher was fitted to the 2.2 diesel cars, don't know about the 2.5s
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #3 on: 17 November 2011, 13:27:20 »
Hi,
I have something. Just let me know your email address. Have the same on my car (2.2 DTI), seems that is not working too. I'd like very much to find out what went wrong with yours.
2woody
  • Northumberland
« Reply #4 on: 17 November 2011, 15:06:19 »
its really nothing to do with the engine. This is a stand-alone diesel-powereed coolant heater.
mantahatch
« Reply #5 on: 17 November 2011, 15:22:31 »
If it is anything like the one on the Seat Alhambra, after three overheat faults it shuts down for good, or until you fix it anyway.
Jack-V6
  • Netherland
    • opel omega portal
« Reply #6 on: 17 November 2011, 18:51:39 »
This auxiliary heater is mounted on multiple brands and types.
Also on several diesel versions of the omega.
How can i fix it. Is this an electrical blockage. I've heard that the glow plug often has a failure.
Gr jack
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #7 on: 18 November 2011, 07:12:01 »
I have a manual for this, in pdf. I will send it to you provided that you'll send me the email address (otherwise don't know how to proceed). I've contacted Eberspaecher branch and they said that for Omega I should go to the Opel service to have a Tech2 check for error messages. Eberspaecher said they can not check for errors on Omega, using their gear. Having the manual that I will send to you is easy to check with an electrician the fuel valve & pump (external bits), but I would advise you to go to Eberspaecher to open the damn thing if required.
Jack-V6
  • Netherland
    • opel omega portal
« Reply #8 on: 18 November 2011, 09:14:43 »
That's exactly what she told me. Now I'm looking for an "My Naff Code Reader" set so I can read it out for myself.
Thanx for the pdf file.
grtz Jack
Page created in 0.039 seconds with 16 queries.
