Wanted - Park Pilot Speaker
Started by star_whites, 16 November 2011, 22:54:19
star_whites
As per the title, I'm looking for a park pilot speaker for a 2001 Elite Estate!
More cost effective to use a modified tweeter. A lot cheaper and more reliable
Quote from: RobG on 17 November 2011, 17:00:58
Any louder? I struggle to hear mine with the radio on  :-\
Quote from: tunnie on 17 November 2011, 17:16:14
Yep, louder. Got mine positioned behind the front passenger upper seatbelt trim
Quote from: RobG on 17 November 2011, 17:19:23
Thats a mod to add to the list, cheers  :y
Got mine on the screen & the top of each door .................... they're completely silent too!  ::) ::) ::)
star_whites
But do you have to modify the tweeter first?
I think hes asking what exactly has to be modified Rob. ;).............was wondering myself actually. ::) ;D
Quote from: Albs on 17 November 2011, 18:06:17
I`ll post up some pics later
Thought you might have a pic somewhere. ::) ;D
Get a tweeter from a breaker ideally with the connector & length of cabling.
Cut wires arrowed, remove capacitator, solder cut wires together, job done.
zirk
Never taken an omega one apart but guessing theres a coil in there somewhere, so standard cross over would be Capacitor in series and Coil afterwards in parallel (the bits that need to come out.
Can I be bold and say I think the OP is after a speaker for His Parkpilot (confirm?) the bit that makes the noise, Rob's mod is to replace the rear sensors, or am I just not reading this correctly?
Chris  :-\
Quote from: zirk on 17 November 2011, 19:50:07
Chris  :-\
the parkpilot speaker
zirk
Quote from: RobG on 17 November 2011, 19:59:56
Chris  :-\
Ok I got it wrong then, I thought you were modifying the tweeters to use a sensors, probably explains why I gave you a silent 'not sure about that look' when you told me.
sorry Rob   :D :D
