Author Topic: car reving on its own  (Read 1888 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
« on: 18 November 2011, 18:54:41 »
Hi after replacing the oil cooler due to a leak, the car does not run smoothly anymore. :'(
when you start it up it runs between 600 to 1500 rpm and keeps like this even whist driving almost like the throttle is sticking.
Any Ideas
Many Thanks
Re: car reving on its own
« Reply #1 on: 18 November 2011, 19:16:15 »
Possible vac leak. Doublecheck all your work
downsmen
  • Kent
« Reply #2 on: 18 November 2011, 19:19:01 »
is there a diagram or picture of where all the vacum pipes go etc? :y
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #3 on: 18 November 2011, 19:19:49 »
Have you re-assemble the throttle cable correctly? Assuming you have the 2.5 or the 3.0 :-\
downsmen
  • Kent
« Reply #4 on: 18 November 2011, 19:24:04 »
i think i did
not sure now!!!!!
« Reply #5 on: 18 November 2011, 19:25:35 »
« Reply #6 on: 18 November 2011, 19:26:13 »
With the engine running, spray around the vac pipes/plenum LIGHTLY with carb cleaner, if the engine note changes the carb cleaner has been sucked in and burned as unmetered fuel ... you have just found the vac leak !!
Rectify, check again, once happy wipe down with paper towel.
Result : fixed vac leaks and a nice clean engine :)
downsmen
  • Kent
« Reply #7 on: 18 November 2011, 19:32:17 »
Thanks :y
i shall try that in the morning
downsmen
  • Kent
« Reply #8 on: 19 November 2011, 22:37:16 »
Thanks guys for your advice :y
i found a split hose on the back of the plenum, new one fitted and all fine again now.
Thanks again :y :y
« Reply #9 on: 19 November 2011, 22:49:26 »
Thanks again :y :y
Result!!  :y :y
