Author Topic: ECU Limp Home mode  (Read 1077 times)
peter murray
  • hARROW
    • OMEGA 3.2 2003
ECU Limp Home mode
« on: 21 November 2011, 16:01:24 »
Occasionally the car goes to Limp Home mode and a warning light which looks like a car with a spanner comes on. If I turn off the engine this will normally clear the fault (as per the handbook). The fault usually comes on after a long drive.
Having looked round the forum I saw a post which said that a failing knock sensor could be the problem.
Can anyone help?
The car is 3.2 Elite 2003 model.
Re: ECU Limp Home mode
« Reply #1 on: 21 November 2011, 16:03:44 »
Do the "pedal trick" and post up the codes
http://www.omegaowners.com/forum/index.php?topic=90581.0
peter murray
  • hARROW
    • OMEGA 3.2 2003
« Reply #2 on: 21 November 2011, 16:45:45 »
DOING PEDAL TRICK SEEMED TO GIVE THE FOLLOWING SEQUENCE OF FLASHES:
10 4 2 10
HOPE THIS MAKES SENSE AS IT IS DIFFICULT TO COUNT!
THANKS AND REGARDS
PETER MURRAY
woodoo
  • Heanor
  • www.woodoo.yolasite.com
    • Vauxhall Omega 2.0l Auto
« Reply #3 on: 21 November 2011, 17:16:31 »
0420 catalytic converter system, bank 1 - efficiency below threshold. Problem cause: Catalytic converter, wiring, lambda sensor(after cat). Hope this helps.
« Reply #4 on: 21 November 2011, 17:21:19 »
Good job you didn't waste money on that knock sensor - another lesson in not changing stuff on a hunch ;)
0420 (and 0430) plague all 3.2 engines.  Ultimately, the solution is to move the rear lamdas behind the main cat. Costs about £15 and a couple of beers to your welder mate ;)
« Reply #5 on: 21 November 2011, 17:34:48 »
Yeah the pre-cats fail, sensors need moving post main cat  :y
« Reply #6 on: 21 November 2011, 17:37:28 »
Although this code should not give any form of limp, it just brings light on...
