Author Topic: led bulbs  (Read 2336 times)
big mel
  • Oldham Lancs
  • ex trucker' GB. USA. CONTINENT& GB
    • Omega 2ltr gls 2000frpp
    • big melL
led bulbs
« on: 25 November 2011, 17:18:52 »
hi. are led bulbs safe to use in mig stop/tail flashers & internal lights? I am thinking of re-placeing mine are there any mig owners that have them fitted? tia. mel.
THE TRUCKERS MOTTO. keep the shiny side up & the greasy side down. the bugs off your glass &  the bears off your ass.
Re: led bulbs
« Reply #1 on: 25 November 2011, 17:22:52 »
just fit a standard bulb, in the 7 years I've owned my 2.2, I've never had to replace any bulbs in the rear cluster, only ever had 1 dipped beam bulb blow
Re: led bulbs
« Reply #2 on: 25 November 2011, 17:28:27 »
I'm sure they'll be 'safe' to use, but I wouldn't be surprised if they upset the lamp check system & upset the flash rate of the indicators - some have inbuilt resistors, others don't.  :y :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: led bulbs
« Reply #3 on: 25 November 2011, 17:51:01 »
Resistors will be needed for the flashers, but not the stop and tail.
Apart from the bulb monitoring circuits generally not liking them, I personally would not fit LED bulbs, as from the extensive research we have done with both clear and coloured LED replacements behind clear and coloured lenses, they are just not as bright as conventional bulbs.
Other thing I would suggest, is to replace (when you need to) with a branded bulb like "Ring" as they seem to be of a higher quality than most of the Chinese tat that is out there.
Radio & Decoding Technician
www.dndservices.co.uk
big mel
  • Oldham Lancs
    • big melL
Re: led bulbs
« Reply #4 on: 26 November 2011, 19:32:51 »
thanks for the advice to you all. will stick to the type that are fitted. mel.
flyer 0712
Re: led bulbs
« Reply #5 on: 26 November 2011, 20:10:33 »
Hi  i have done this to my omega...blue l e d  panel lights and white side lamps...they were quite expensive...and a complete  waste of time and money....stick to the originals as they are far brighter and better.. :y
