Author Topic: Temperature needle  (Read 1342 times)
Omega paul
Temperature needle
« on: 25 November 2011, 20:21:11 »
Hi can you help me with a problem my temperature needle has stop working.the car warms up ok but the needle do's not move could this be that it needs a new temp sender or a blown fuse and where is it on a 2.2 engine hope someone can help thanks?
Re: Temperature needle
« Reply #1 on: 25 November 2011, 20:24:27 »
Hi Paul
On the 2.2, at the rear NS of the engine, there is a small spade connector - my money is on that having come adrift, rather than anything to worry about.
What's your location? There may be a nearby member who could cast an eye? :y
Cheers,
James
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 25 November 2011, 20:30:00 »
« Reply #3 on: 25 November 2011, 20:36:19 »
Here you go mate. Ignore the "coilpack" you won`t have one fitted
« Last Edit: 25 November 2011, 20:38:49 by RobG »
woodoo
  • Heanor
  • www.woodoo.yolasite.com
    • Vauxhall Omega 2.0l Auto
« Reply #4 on: 25 November 2011, 21:23:20 »
It has no fuse for this sensor. Check blue sensor wire and if it is ok then i think you need new sensor.
Omega paul
« Reply #5 on: 26 November 2011, 17:43:47 »
Thanks for that the wire had come off and is now working fine
« Reply #6 on: 26 November 2011, 18:32:33 »
Sorted.  :y :y
for future reference, if you ground the blue wire (ie connect to earth or zero volts for the electronics bods) the temp gauge should go to fully hot ie full deflection of the gauge.  :y :y :y
