Author Topic: headlight adjuster (UPDATE)  (Read 1916 times)
Latchie_3.0v6
  • OMAGH N.IRELAND
    • Omega 3.0 v6 elite (sold)
« on: 26 November 2011, 13:43:48 »
Just took a few pictures today to show everyone the problem that i have and maybe someone can help
The only way forward is sideways
Re: headlight adjuster (UPDATE)
« Reply #1 on: 26 November 2011, 14:15:07 »
It appears that the wishbone was replaced with one that didn`t have the pre-drilled holes for the "toggle" arm part of the sensor and hence has not been fitted
Latchie_3.0v6
  • OMAGH N.IRELAND
« Reply #2 on: 26 November 2011, 14:17:45 »
i was thinkin along those lines couldn't see anywhere that anything could connect to.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 26 November 2011, 15:39:29 »
Mine was the same. It's obviously too hard to drill a 6.5mm hole, so breaking the arm off the sensor makes much more sense! Quite how you would explain to the customer that changing the wishbone causes a 'headlight aim' warning every time the car's started is beyond me.
Latchie_3.0v6
  • OMAGH N.IRELAND
« Reply #5 on: 26 November 2011, 16:12:31 »
Is there a sensor on the rear aswel if so what side and where abouts
« Reply #6 on: 26 November 2011, 17:13:45 »
Yes, near side radius arm - same switch, just a different bracket.  :y
(the sensor on the driver's side is for you self levelling suspension  ;))
Latchie_3.0v6
  • OMAGH N.IRELAND
« Reply #7 on: 26 November 2011, 18:53:29 »
Does that mean it has nothin to do with the lights. Is it just the front sensor for the the lights.
« Reply #8 on: 26 November 2011, 19:14:31 »
No. Both near side sensors talk to each other to keep the lights level.
The driver's side sensor just does the suspension & is a completely separate system from the HID level sensors.  :y
