Author Topic: Gearbox Faults  (Read 985 times)
Corrado1441
  • N.Ireland
    • Vauxhall Omega Elite
Gearbox Faults
« on: 27 November 2011, 21:15:52 »
Hi was wondering if Omega's suffer from Auto gearbox problems ? Car is a 1996 Elite Petrol with 100k miles on it.
Thanks
Re: Gearbox Faults
« Reply #1 on: 27 November 2011, 21:35:19 »
Generally no. ATF should be changed every 60k miles..
Thrust washers are the weakest point usually...
Corrado1441
  • N.Ireland
Re: Gearbox Faults
« Reply #2 on: 27 November 2011, 21:53:58 »
Better change the fluid then to be safe :-)
Re: Gearbox Faults
« Reply #3 on: 27 November 2011, 22:17:20 »
There is a plastic thrust washer that tends to break up and cause gearbox failure. If you find any evidence of it in the sumps when you change the fluid then it needs to be replaced. Other than that, keep the fluid fresh and they are reliable.
  • Auckland
    • Mazda MPV
Re: Gearbox Faults
« Reply #4 on: 27 November 2011, 22:26:26 »
Unless...
you drive through deep water and get the selector switch wet
Or
you are unlucky and one of the change solenoids fails
(both of these can be fixed without taking the box out of the car though)
Page created in 0.008 seconds with 16 queries.
