Author Topic: Retrofitting a rain sensor  (Read 6565 times)
Re: Retrofitting a rain sensor
« Reply #15 on: 28 November 2011, 19:24:25 »
Nope - the normal mirror wouldnt fit onto the mount on that screen.Thats why I nicked Twiglets rain sensor type mirror. ;)
So,presumably that type of mirror wont fit onto the mount on the normal screen.
Ok, I never got as far as the mount bit, if thats the case then thats cumming off and getting stuck back on where its needed when ever I get round to doing it.
Think I wait for you to fit yours and blow your one up first, before I do my one in.
You know me so well. :y ;D ;D
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #16 on: 29 November 2011, 06:54:46 »
Yes, although it might be possible without replacing the windscreen, I will replace it (small crack on it and even worse, a lot of fine scratches, very disturbing during night driving :()
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #17 on: 29 November 2011, 14:03:28 »
Hi guys,
Look what I found in Germany :):
http://www.omega-freak.de/forum/1706-regensensor.html?highlight=regen+sensor
(Google translation from German. Disc=windscreen, etc.) It looks like it is not that hard.
"So, I got my rain sensor installed and it works perfectly! For those who also want to retrofit a small tutorial here ne time with the built parts of me:
first time do the old windscreen out ...
http://www.opelcars.de/forum/regensensor/DSC00332.jpg
... and a new one with rain sensor mount purely - windscreen heat resistant (SolarRelex) with rain sensor mount
http://www.opelcars.de/forum/regensensor/DSC00333.jpg
- rain sensor for heat-resistant windshield part number: 93,171,184 Catalogue number: 6238211 = 151.72 EUR..
http://www.opelcars.de/forum/regensensor/DSC03285.jpg
http://www.opelcars.de/forum/regensensor/DSC03286.jpg
- 2 relay Part No:. 90,543,014 Catalogue No:. 6238564 = 26.18 EUR
http://www.opelcars.de/forum/regensensor/DSC03287.jpg
- wiring harness (homemade) = 0.00 EUR -
http://www.opelcars.de/forum/regensensor/DSC03288.jpg
- cover for the rain sensor and the mirror mount Part No: 93,172,242 Catalogue number: 6428872 = 5.65 EUR..
http://www.opelcars.de/forum/regensensor/DSC03282.jpg
http://www.opelcars.de/forum/regensensor/DSC03283.jpg
Current (+ PIN 1 and neutral PIN 4 of the sensor) I've taken from the interior lights and pulled out all the other cable to the A-pillar on the driver's side down to the fuse box. There, then after switching to plan for rain sensor http://www.opelcars.de/forum/regensensor/mit_Regensensor.pdf (here the diagram without rain sensor for comparison http://www.opelcars.de/forum/regensensor/ohne_Regensensor.pdf) and then connected the relays and with power thieves the cable from the wiper switch tapped. In the engine compartment from the relay box nor the interval relay (a rather large yellow part) pulled out. And then to test spray water on it. If everything works you have it connected properly and you can grow the panels. So, that's it. If not then ask her that. MFG"
http://www.youtube.com/watch?v=RgLBHVdnH6A&feature=player_embedded
Looks that 2 relays are needed also. I don't speak German so I don't know whether the retrofit was done on a car with wiper speed wheel or not.
« Last Edit: 29 November 2011, 14:16:40 by gaby63 »
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #18 on: 29 November 2011, 14:55:07 »
Apparently it was fitted on a prefacelift Omega.
« Reply #19 on: 29 November 2011, 20:07:36 »
Not in UK. Non UK cars did get different specs, although was not aware this was ever fitted to prefacelifts :o
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« Reply #20 on: 30 November 2011, 06:13:51 »
I mean: the tutorial is about a rain sensor installed in a prefacelift Omega, which initially  was not equipped with it.
VOYAGER
  • ANKARA/TURKEY
    • 1998 Omega CD V6 AUTO
« Reply #21 on: 13 October 2012, 21:48:14 »
I just want to retrofit the rain sensor but, I need little bit more details such as relays' locations and the pin numbers on the rain sensor which has 8 pins on it... :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #22 on: 14 October 2012, 17:12:41 »
          ive had rain sensing wipers on all my omega's
   i use part no "mk 1 eyeballs" work dam well and never had a fault with them. ;D
Hoof'land storeman.
Page created in 0.024 seconds with 16 queries.
