Author Topic: Retrofitting a rain sensor  (Read 6666 times)
gaby63
  • Sibiu, Romania
    • 01 2.2 DTI
« on: 28 November 2011, 13:45:44 »
Does anyone know how to retrofit a rain sensor? I've purchased the rain sensor and sensor housing. My Omega is a 2001 model (with intermittent wiper speed adjusting button).
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Retrofitting a rain sensor
« Reply #1 on: 28 November 2011, 13:57:41 »
Your also need the rain sensor wiper stalk I believe (Saloon and Estates are different) to replace the variable wiper one.
Not sure about Opels in your country and when the rain sensors where introduced over there but Im guessing for a 2001 you probably need extra wiring.
Chris.
« Last Edit: 28 November 2011, 13:59:32 by zirk »
« Reply #2 on: 28 November 2011, 15:58:27 »
I have the same job to do at some time.Will be interested to see the answers to this one. :)
« Reply #3 on: 28 November 2011, 18:11:20 »
You will need a new windscreen as well ::)
« Reply #4 on: 28 November 2011, 18:12:13 »
Done that bit. ;)
« Reply #5 on: 28 November 2011, 18:18:00 »
Done that bit. ;)
Not looked that closely, but guess its just simple wiring then ;)
« Reply #6 on: 28 November 2011, 18:21:48 »
Simple wiring = brown + , blue -, yellow/green, earth. Beyond that....... ;D
zirk
  • Epping Forest
« Reply #7 on: 28 November 2011, 18:27:50 »
Why new screen?
« Reply #8 on: 28 November 2011, 18:33:09 »
Different mirror mount and darkened area around that area of the screen to accomodate sensor below mirror. You were there when my screen was fitted and we discovered these small facts,but istr you were digging around in all those boxes in Twiglets garage. ;) ;D
« Reply #9 on: 28 November 2011, 18:39:10 »
Oh dear.....
Br - live
Bl - neutral
Y/Grn - earth
« Reply #10 on: 28 November 2011, 18:40:50 »
Swotiment. :y ;D
zirk
  • Epping Forest
« Reply #11 on: 28 November 2011, 18:42:45 »
Yep, surprising what you can find in those boxes when His backs turned.
Yea, I do remember that Albs, but when I looked into it further the Rain Sensor screen is only designed so that you cant see the sensor, it should still work on a normal screen, you could blank out the area thats not required if need be with some black stick on PVC cut out.
« Reply #12 on: 28 November 2011, 18:49:59 »
Nope - the normal mirror wouldnt fit onto the mount on that screen.Thats why I nicked Twiglets rain sensor type mirror. ;)
So,presumably that type of mirror wont fit onto the mount on the normal screen.
zirk
  • Epping Forest
« Reply #13 on: 28 November 2011, 18:58:58 »
Ok, I never got as far as the mount bit, if thats the case then thats cumming off and getting stuck back on where its needed when ever I get round to doing it.
Think I wait for you to fit yours and blow your one up first, before I do my one in.
« Reply #14 on: 28 November 2011, 19:22:25 »
No idea of part numbers, but Vauxhall does/did an add on rain sensor kit. Dr O priced it up for me when SWMBO had an Astra without a variable intermittent wipe. IIRC it was expensive (£150? ) so it didn't get bought.
Those with access to EPC might be able to advise ......  :-\ :-\ :-\
