Author Topic: tensioner pully  (Read 1962 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
tensioner pully
« on: 28 November 2011, 15:39:02 »
Where is the best place to get a utility belt tensioner pully from ?
Any idea of approx price ?
I think mine is squeeling its nuts off under load.
Also noticed that belt is starting to slip on the free wheeling power stearing pump pully with it switched off.
Pump turns ok with the aircon switched on
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: tensioner pully
« Reply #1 on: 28 November 2011, 15:47:13 »
It might just need repacking with grease. From what I can remember when I did mine, undo nut, take off pulley, remove large metal washer / cover from each side and pack with grease.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: tensioner pully
« Reply #2 on: 28 November 2011, 15:54:53 »
Cheers Rod  :y
I'll give it a try
I hope this is the problem  :-\
I've been trying to track down this whine for weeks now.
I'm half deaf in one ear and everybody who sits in the car says its coming from a different place  ::)
Trouble is, you only hear it when the car is accelerating hard.
You can hear break all when its stood still  ::)
I ended up takeing the end plate of the diff last week because I thought the noise was back there  :-[
Re: tensioner pully
« Reply #3 on: 28 November 2011, 16:40:31 »
Once you've got it off, if it's just dry, as said, prise the plastic covers off each side of the bearing (a pin works well here) and pack with grease.
If the bearing has significant play in it, it's best to replace the pulley.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: tensioner pully
« Reply #4 on: 28 November 2011, 16:48:01 »
Any idea on the cost of a new one ?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: tensioner pully
« Reply #5 on: 28 November 2011, 17:39:25 »
About £30 - bought one a couple of weeks ago
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: tensioner pully
« Reply #6 on: 28 November 2011, 17:47:27 »
Thanks all  :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: tensioner pully
« Reply #7 on: 28 November 2011, 17:50:37 »
Part Number V0009157962 - Purchased 15/11/11 - £25.70+vat
marrus69
  • bracknell
    • 52 mv6 3.2
Re: tensioner pully
« Reply #8 on: 28 November 2011, 18:03:06 »
jumping in here saves me starting new post
ive got the same problem wines and grinds on a v6,is it just the wheel can i just undo it,if iys just a tensioner how do i relese it.as you look at engine its the top left wheel.man from vauxhall said it was just a belt tensioner.
Re: tensioner pully
« Reply #9 on: 28 November 2011, 18:09:23 »
If its just the bearings that need sorting, remove aux belt, then undo the 15mm nut that holds pulley to tensioner.
Re: tensioner pully
« Reply #10 on: 28 November 2011, 19:13:20 »
To release tension on belt - 15mm socket with bar onto nut on tensioner pully and pull bar towards passenger size.
maracus
  • Cambs
  • Hahaha cool- 1000+bhp combined on the drive!!!!!!!
    • 3.0mv6 auto, cav4x4 turbo
Re: tensioner pully
« Reply #11 on: 28 November 2011, 19:58:06 »
I done mine the other day as it had play- only a little and didnt make noise but hey, done it anyway for longevity purposes, easy peasy! Used one of them precision flat blade screwdrivers, perfect :) take are not to damage It though, just the right amount of force else it springs back in lol.
...it hasn't fallen off yet so must'a done something right lol
The weather is here... Wish you were beautiful!
marrus69
  • bracknell
    • 52 mv6 3.2
Re: tensioner pully
« Reply #12 on: 29 November 2011, 10:35:34 »
my pully was £34, all done hard work pushing pully and trying to get belt of same time.have to wait and see wot goes next.
