Author Topic: cylinder head torque ftbak  (Read 2756 times)
gibby
  • braintree
« on: 29 November 2011, 06:58:57 »
 hello hei guys, I just want to report about the head gasket done some few days ago: I removed the cams and retorqued the bolts 90 +15 degs. One front bolt seems abit weak though. Reassembled everything, I cudn't trace where to fit one pipe at the back of the engine driver's side. I started the engine, it went vroooooom!!!!!!! but vibrating vigorously with rough sound like a 7 tonner truck. I want to go back on it today to see whats happening. if anyone has got ideas, pliz advise, I know there are some experts there. May the Lord bless u all as we are approaching Xmass, gibby
Re: cylinder head torque ftbak
« Reply #1 on: 29 November 2011, 08:36:02 »
90 +15?
sounds very wrong to me..
thought it was 25, then 4 x 90's or something like that
spare pipe probably auto gearbox breather.
Everything else reconnected? any fault codes?
Ohh, and what engine?  any can run rough for a bit after this sort of work.
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
« Reply #2 on: 29 November 2011, 08:37:29 »
did you change your cambelt too and placed it right on??
Witch engine are you talking about?  Do you have a picture of the pipe.
tought that for a v6 the torq was 60Nm 4x90° 1x 15°
« Last Edit: 29 November 2011, 08:40:09 by Jack-V6 »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #3 on: 29 November 2011, 08:43:30 »
hi guys its a z22se
tightening should be
25nm
90deg
90deg
90deg
optional 15deg tolerance turn
op originally only done first 3 stages re-  http://www.omegaowners.com/forum/index.php?topic=96225.0
but did start car with the torque settings that he had done
yes is an auto so pipe could be autobox breather  :y
fiend61
  • york
  • each to their own
« Reply #4 on: 29 November 2011, 08:49:25 »
been looking but cant find a vac pipe layout for the 2.2 ?
gibby
  • braintree
« Reply #5 on: 29 November 2011, 09:09:13 »
90 +15?
hello, yea at first I torqued on 25nm, 2x90 only then yesterday after some pieces of ideas I removed the cams and retorque 1x90+15 degs. the engine size is 2198cc(2.2l) cdx z22xe 2001 auto estate, thx 4 ur time, be blessed
« Reply #6 on: 29 November 2011, 09:27:49 »
Does it idle at normal speed?
Can you describe the noise a little more? Is it a knocking sound, tapping or is the engine just misfiring? Can you listen around the engine to determine where the sound is coming from? Up front under the cam belt cover perhaps? Top end under the cam cover? bottom end?
Can you read the fault codes from the engine ECU?
gibby
  • braintree
« Reply #7 on: 29 November 2011, 17:55:31 »
hi sir, I have been working on it and now its running smoothly, the prob was one of the heater not sure though but those electrical parts that are on top the fuel injectors was not plugged well in its hole. thax very much for your advice, may the Lord bless you
gibby
  • braintree
« Reply #8 on: 29 November 2011, 17:57:51 »
:) hi sir, I have been working on it and now its running smoothly, the prob was one of the heater not sure though but those electrical parts that are on top the fuel injectors was not plugged well in its hole. thax very much for your advice, may the Lord bless you
gibby
  • braintree
« Reply #9 on: 29 November 2011, 18:04:21 »
 :) hello mates, I've good news now my Speed Bird is is running fine. I have been working on it and now its running smoothly, the prob was one of the heater not sure though but those electrical parts that are on top of the fuel injectors was not plugged well in its hole. thax very much for your advice, may the Lord bless you ALL
