Pages: 1 2 [3]  All   Go Down
Author Topic: Finally found my course. Also some maintenance Q's.....  (Read 9094 times)
Re: Finally found my course. Also some maintenance Q's.....
« Reply #30 on: 30 November 2011, 22:18:51 »
Thought jack would not really be amazing, but thought it would get it high enough  :-\
Point taken on trade  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #31 on: 01 December 2011, 10:40:46 »
A point on jacking and axle stands. The underside of your car will be undersealed, and jacking straight onto the underseal may well damage the seal, and possibly the metal chassis, as jacks have lugs around the jack plate to prevent slippage. More expensive jacks, as used in some garages, have a rubber pad on the plate to prevent this damage. To protect my chassis from such damage, I make up an appropriate block of wood or rubber to fit the jack plate, and the weight of the car, if on level ground, will prevent it slipping if jacked in the correct place. Axle stands, because of their shape, and with correct positioning, are less likely to cause damage, however I still use protective measures.
To find the jacking points on a car, refer to the owner's or workshop manual. There is invariably a jacking point to take a hydraulic jack, just inboard of the point where the car's wheel change jack is designed to fit, and you will see tyre fitters putting the jack there as a matter of course. There are often other places on the underside of any car's chassis which MAY be safe to use as jacking points, sometimes with timber used as a load spreader, but you will no doubt learn about this on your mechanics course, and with experience.
My apologies if I am telling you stuff you already know.
Best wishes and good luck on the course. :y :y :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #32 on: 01 December 2011, 19:43:27 »
My apologies if I am telling you stuff you already know.Best wishes and good luck on the course. :y :y :y
not at all mate. i need ALL the advice i can get.
spent a really good day with the pink one. he went through everything with me and although i think i'd still be stumped a bit with the fuel filter......... the oil change, oil filter, air filter, pollen filter will defo be something i can do  :y also didn't realise the s.plugs were accessible without removal of plenum... although looks awkward to get at the right hand side  ::)
im defo going to get that kit that tunnie recommended. then im away  :y
thanks again guys and big thanks to DLK for his time and effort in helping a complete novice!!  :y :y :y :y
RIP Paul Lovejoy
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #33 on: 01 December 2011, 19:51:24 »
No problem Steve your welcome anytime  :y
A few tools will be a help.
Daz
Webby the Bear
  • Northampton
« Reply #34 on: 01 December 2011, 19:57:14 »
Daz
Cheers mate   :-* :-* :-*:y :y :y :y
btw, i don't think i mentioned... i have a new door strap bush to put on. on reading the guides a well greased replacement will remove that horrid clicking/cracking noise when drivers door is open... iirc you had same on your black mv6 that i was introduced to at the farm. did you do the same?
RIP Paul Lovejoy
« Reply #35 on: 01 December 2011, 20:16:39 »
Daz
Those washers are fitted dry.
Webby the Bear
  • Northampton
« Reply #36 on: 01 December 2011, 20:19:50 »
Daz
oh..... this guide says to grease well...
http://www.omegaowners.com/forum/index.php?topic=90525.0
RIP Paul Lovejoy
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #37 on: 01 December 2011, 20:25:30 »
 ;D ;D ;D
And so it does  ;D
« Reply #38 on: 01 December 2011, 20:29:03 »
;D ;D ;D
And so it does  ;D
What idiot wrote that guide ::)
Webby the Bear
  • Northampton
« Reply #39 on: 01 December 2011, 20:31:24 »
;D ;D ;D
And so it does  ;D
lol!
i'll fit dry  :y thank you.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #40 on: 05 December 2011, 18:53:19 »
Hi All,
Are these ramps suitable for the Omega as an alternative to the Axel Stands??......
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_175876_langId_-1_categoryId_255207
I'm going to be honest I am really a bit nervous about putting the car on those stands.  :-[
Do you drive up these ramps or jack up and place front wheels each at a time?
Cheers  :y
RIP Paul Lovejoy
« Reply #41 on: 05 December 2011, 18:56:00 »
Omega is a pain on ramps, because of the long nose/back - you need to extend ramps with planks.
You will need stands anyway to do wheels/brakes/suspension etc.
As previously said, more than willing to show you std maint tasks, if ever you pass my end of the A43.
« Reply #42 on: 05 December 2011, 18:58:18 »
For £60 you`ll still need extensions. Get both here for £37 delivered with a greater weight capacity
http://www.ebay.co.uk/itm/1-PAIR-2-5-TONNE-CAR-RAMPS-WIDE-RAMP-EXTENTIONS-/290615173930?pt=UK_Lifting_Moving_Equipment&hash=item43aa03a32a
Webby the Bear
  • Northampton
« Reply #43 on: 05 December 2011, 18:58:56 »
That's  what I thought, but thought I'd check  :y
Thank you very much. I want to do a coolant flush. Would it be ok to pop up one Sunday?  :)
RIP Paul Lovejoy
Pages: 1 2 [3]  All   Go Up
Page created in 0.025 seconds with 20 queries.
