Author Topic: idle speed  (Read 1795 times)
flyer 0712
idle speed
« on: 30 November 2011, 18:07:14 »
hi all     can any body tell me what the idle engine speed should be on my 2000    2.2 omega  automatic please......in drive   and out of drive at a standstill      thanks   ray.. :y
Re: idle speed
« Reply #1 on: 30 November 2011, 18:26:58 »
about 850rpm from memory, might drop to 750 in D with foot on brake.
flyer 0712
Re: idle speed
« Reply #2 on: 30 November 2011, 19:28:52 »
ok  thank you ...mine is around   650 rpm   out of gear and makes the car vibrate..when i increase the revs to around 800 the vibration evens out......can it be altered or could there be another reason for it...i have changed the drivers side engine mounting as it was a bit shabby and the other side looks ok......only it is driving me mad....any ideas please...thanks ray
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: idle speed
« Reply #3 on: 30 November 2011, 19:49:55 »
Engine warm or cold?
Warm engine should be 650-700RPM when in Drive, footbrake applied.  Higer for a Cold Engine.
Could you ask someone (pref a trusted friend and not the wife  ;D) to put the transmission into gear and put their foot on the brake as you look under the bonnet?
Might give you some indication as to where the vibration is comeing from.
flyer 0712
Re: idle speed
« Reply #4 on: 30 November 2011, 22:07:07 »
with engine cold and reving higher its ok.....when warm revs dropped back it starts vibrating.....i will try what you advised tomorrow with a good friend at the wheel   ( not the other half....such temptation  for her )  thanks to all    ray....
