Author Topic: Brake Problems - Master Cylinder  (Read 3097 times)
star_whites
  • Rotherham
« on: 04 December 2011, 13:22:52 »
Ok, I've just got round to removing the brake master cylinder off my 2001 2.6 and I have an urgent question::
The master cylinder I have removed has the numbers 2017 (symbol) 1 written underneath, however the one I bought off albs had 2017 (symbol) 2 written on it. Does this mean it's the wrong one or is it just a newer model????
« Last Edit: 04 December 2011, 13:29:36 by star_whites »
star_whites
  • Rotherham
Re: Brake Problems - Master Cylinder
« Reply #1 on: 04 December 2011, 14:14:37 »
No one got any ideas as was hoping to get this fitted this afternoon?? ???
« Reply #2 on: 04 December 2011, 14:27:48 »
the size is cast into the body of the master cylinder on the top, below the reservoir
star_whites
  • Rotherham
« Reply #3 on: 04 December 2011, 14:32:41 »
They both say Lucas and the number 25 stirrer on them.
« Reply #4 on: 04 December 2011, 14:34:56 »
star_whites
  • Rotherham
« Reply #5 on: 04 December 2011, 14:38:01 »
Damn phone. They both have Lucas 25 stamped on to the top of them!......does this mean they are the same??
« Reply #6 on: 04 December 2011, 14:42:22 »
Yep, some master cylinders on the Omega had a 25/20 split bore feeding front/rear. If the one from Albs has identical markings to yours should all be OK
« Reply #7 on: 04 December 2011, 14:44:46 »
Just seen this - thanks Rob. you ride to the rescue yet again. I owe you - again. :y
Star Whites - hope its all OK, if no, let me know. :y
star_whites
  • Rotherham
« Reply #8 on: 04 December 2011, 14:58:04 »
Well it's back on the car, now just to see what happens when bleeding!
star_whites
  • Rotherham
« Reply #9 on: 04 December 2011, 15:22:00 »
Oh my god I have fluid at the caliper  8) :D :y
Only problem now is the new flexi hose I bought is leaking!....glad I bought a spare! ::)
star_whites
  • Rotherham
« Reply #10 on: 04 December 2011, 16:56:51 »
Well hopefully the last update on my brakes, I've replaced the master cylinder and completely bleed the entire system and I have brakes  :D
There not fantastic due to new pads all round and rusty discs due to how long she's been stood but I think after bedding in the new pads and cleaning the discs up they will be ok, believe me they are way better than they were!
Just headlight to dismantle and check if bulbs are seated properly ( due to high beam on drivers side) and she will be off for another mot!! :) :y
Thanks for all your help, especially Albs, top man  :y
« Reply #11 on: 04 December 2011, 16:58:40 »
Glad to hear its (hopefully) all sorted now. :y
star_whites
  • Rotherham
« Reply #12 on: 04 December 2011, 17:07:49 »
Next decision is whether to stick with dot 4 or flush it again with the expensive race fluid I've been given. The guy says it's ideal for my mig especially due to the size of her. He recons it will improve braking distance!
« Reply #13 on: 04 December 2011, 17:16:17 »
Going from vague memory rather than knowledge - racing fluid ,fully synthetic ? not compatible with other types of fluid ?
If this is the case you would need to get all of the old fluid out of the system before putting it in.
Personally,I think Dot4 is more than up to the job.It would take some pretty extreme driving on the road to boil it imo.
« Reply #14 on: 04 December 2011, 17:18:44 »
Good news Star - well done. :y
