Author Topic: handbrake  (Read 1314 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
handbrake
« on: 05 December 2011, 14:38:12 »
Hi
I have just put new discs on all round, now the handbrake does not work.
it worked before really well, i did not replace the shoes as they looked okay.
Do they need replacing?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: handbrake
« Reply #1 on: 05 December 2011, 14:44:22 »
Are they adjusted correctly?
Re: handbrake
« Reply #2 on: 05 December 2011, 14:46:57 »
If your hand brake worked OK before you did the job that would suggest that either the handbrake shoes just need adjusting - I assume you must've backed them off when you did the rear discs, or you've not put it back together properly. At least you still have PARK till you get around to sorting it.  ;) ;)
downsmen
  • Kent
Re: handbrake
« Reply #3 on: 05 December 2011, 15:03:37 »
how do you adjust them?
Re: handbrake
« Reply #4 on: 05 December 2011, 15:09:56 »
downsmen
  • Kent
Re: handbrake
« Reply #5 on: 05 December 2011, 15:19:19 »
Thanks thats a job for tomorrow as its MOT time Thursday. :y :y
Re: handbrake
« Reply #6 on: 05 December 2011, 15:26:12 »
make sure you slacken your handbrake cable as described before you start adjusting the shoes.  :y :y
