Author Topic: hid's  (Read 1841 times)
coolsurfer
  • south wales
    • MV6
hid's
« on: 05 December 2011, 19:05:25 »
hi any one know what K rating the original dip beam bulbs are as i am looking to change my main beam with an up grade kit but would like to match them. also what is the difference between say 5000K and 8000k does 8000K mean brighter? :-\
The best thing about the future is that it only comes one day at a time
woodoo
  • Heanor
  • www.woodoo.yolasite.com
    • Vauxhall Omega 2.0l Auto
Re: hid's
« Reply #1 on: 05 December 2011, 19:11:52 »
No, it's not brighter, 8000K will give you blue color:
http://www.meccaone.org/images/hid-chart.jpg
Original bulb should be somewhere between 5000K and 6000K. I prefer 6000K.
Re: hid's
« Reply #2 on: 05 December 2011, 19:14:29 »
OE dipped HID bulb is 4500K. What upgrade kit were you thinking about for the main beams ???
coolsurfer
  • south wales
    • MV6
Re: hid's
« Reply #3 on: 05 December 2011, 19:22:33 »
was thinking of a hid conversion kit with 6000k to replace the H1's in there at the moment but would match the dip beam bulbs also.
Re: hid's
« Reply #4 on: 05 December 2011, 19:33:57 »
You can't have HID mainbeam (not quite true, but to all intents and purposes for this discussion, near enough).
GM HIDs are 4.5k
coolsurfer
  • south wales
    • MV6
Re: hid's
« Reply #5 on: 05 December 2011, 19:50:26 »
ok so why can't you have hid main beam? is this a law thing?
Re: hid's
« Reply #6 on: 05 December 2011, 19:54:54 »
You do get HID headlights, ie 'bi-xenon' but it's not a separate 'bulb', a shutter moves to give you main or dip. HID are too slow to use as a 'flash'
Re: hid's
« Reply #7 on: 05 December 2011, 20:01:11 »
Indeed, shutters is the only way, not practical to retro fit AFAIK.
I know on one of the sports cars my bro was designing, the front had to be slightly restyled to give extra room for ballast packs and vents due to heat.
coolsurfer
  • south wales
    • MV6
Re: hid's
« Reply #8 on: 05 December 2011, 20:22:03 »
just found this from the department of transport Fact sheet: Aftermarket HID headlamps
December 2006
In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon
 there was a lot more info on this.
http://www2.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps.html
so guess thats it will stick with the standards and up grade to get a cleaner ice look  :'(
coolsurfer
  • south wales
    • MV6
Re: hid's
« Reply #10 on: 05 December 2011, 20:42:54 »
is there any thing similar if i have H1's , not sure at moment what is in my motor will whip one out tomorow and check, as i have never had to change one. need to sort this as i now need to drive dark mountain roads regularly
Re: hid's
« Reply #11 on: 05 December 2011, 21:29:14 »
What headlights do you have - ribbed lenses, clear halogen, or hids?
