Author Topic: omega  (Read 1457 times)
karlinz
  • nelson new zealand
    • 91 opel omega,opel monzas
omega
« on: 06 December 2011, 01:38:41 »
hI looking at buying a 2001 2.5v6 Omega,nice car,but auto goes into limp mode, 95%of the time the car is fine says the owner,but drops into 3rd gear he says its lowvoltage torque control?is that a solenoid or sensor?car is as is so is it a cheap or expensive fix internal of external?auto serviced at 95000km and now done 146000km,any help or comments would be appreiated. Thanks Lindsay.
Re: omega
« Reply #1 on: 06 December 2011, 01:43:27 »
Do you have the actual codes from autobox ecu?
Mean time...
I guess ultimtely it depends on price and availbility of a used box where you are, plus cost of fitting?
Re: omega
« Reply #2 on: 06 December 2011, 02:01:24 »
karlinz
Re: omega
« Reply #3 on: 06 December 2011, 04:46:57 »
Thanks for the replys ill see if i can get the codes,hope fully not a 2nd hand box,nothing much wrecked after 95 over here. Cheers Lindsay
2woody
  • Northumberland
Re: omega
« Reply #4 on: 06 December 2011, 09:52:38 »
it's also a fairly common GM gearbox ( 4L-30E from memory ), so knowledge to fix it might be around you already.
I'd start with Isuzu ( Vauxhall ) Frontera and/or several BMW models
karlinz
Re: omega
« Reply #5 on: 06 December 2011, 21:49:40 »
the owner took the car to holden and they gave the code as 00075,as in the list says torque control circuit short circuit to battery voltage what ever that means, easyor expensive fix, a diy or sparky?is it external or internal? Cheers.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: omega
« Reply #6 on: 06 December 2011, 22:14:45 »
what that code means is that the engine ecu isnt talking to the transmisson ecu, what you need is someone with a tech 2 to find out whats going on  :y
the other thing it could be is either a loose connection or a fault in the wiring loom, but get it checked out by tech2  :y
karlinz
Re: omega
« Reply #7 on: 07 December 2011, 02:56:06 »
Thanks for that wether the owner would do that remains to be seen as he is selling as is,and the car is 4hrs away in Christchurch,makes it difficult, was tryingto get info as to wether easy fix and take car as it is and hopefully not a big expense :-\ :-\
fiend61
  • york
  • each to their own
Re: omega
« Reply #8 on: 07 December 2011, 08:00:40 »
as said could be as easy/cheap as a dodgy/dirty connection or wiring loom fault or it could be as hard/expensive as one of the ecu's failed/failing
needs tech2 to find out whether they are talking to each other  ;)
then it all depends on the price of the car  ;)
« Last Edit: 07 December 2011, 08:11:11 by fiend61 »
