Author Topic: oil overfill  (Read 3243 times)
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
oil overfill
« on: 06 December 2011, 11:47:16 »
hi all
when i bought my omega the garage had over filled the engine whith oil [about 1inch above the max level] will this cause oil to be blown out of the breathers
many thanks kevin
long live the magic tree
its good to be back
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Re: oil overfill
« Reply #1 on: 06 December 2011, 11:55:19 »
It might blow out the crank seals
need to drain off oil and get it back to the correct level
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: oil overfill
« Reply #2 on: 06 December 2011, 12:02:42 »
as above, i would get it down to the correct level tbh. :y
ozzycat
    • hyundia i30
Re: oil overfill
« Reply #3 on: 06 December 2011, 13:57:06 »
ok willdo thanks very much for help
its good to be back
Re: oil overfill
« Reply #4 on: 06 December 2011, 14:00:03 »
It can blow out from all sorts of places,including up past the rings, causing hydraulicing.I wouldnt drive the car again until it has been brought down to the correct level. ;)
Re: oil overfill
« Reply #5 on: 06 December 2011, 14:02:44 »
You mean you don't fill till the oil is level with the top of the filler neck?  ::) ::) ::) ;D
Re: oil overfill
« Reply #6 on: 06 December 2011, 14:05:17 »
Saw someone do that on a forklift years ago.Wrecked the engine. ;)
ozzycat
    • hyundia i30
Re: oil overfill
« Reply #7 on: 06 December 2011, 14:10:44 »
bugger ive been doinng it wrong all these years i will do a complete oil and filter cn
hange tomorow then i know its wright
thanks for the help  kevin
its good to be back
Andys VXR
  • cambridgeshire
    • 3.2 Special
Re: oil overfill
« Reply #8 on: 06 December 2011, 14:21:29 »
I wouldnt go back to that garage again if they cant do a simple thing like check oil level god knows what they have done drain it all out get a filter and put fresh oil in it . I went round a friands once and he was trying to top his oil up through the dip stick tube lovely
ozzycat
    • hyundia i30
Re: oil overfill
« Reply #9 on: 06 December 2011, 15:06:41 »
the garage is where i  bought it from last week i normaly do my own work as i was a motor eng before i was diabled
may thanks
its good to be back
Ian_D
  • York
Re: oil overfill
« Reply #10 on: 07 December 2011, 00:11:17 »
I wondered why the man at vx looked at me funny when I ordered 1 oil filter, and 205L drum of oil for my last service....  ;D
[size=12]
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: oil overfill
« Reply #11 on: 07 December 2011, 08:55:26 »
depends where the top of the filler neck is andy  ;D ;D
re-  http://www.omegaowners.com/forum/index.php?topic=96000.0
maracus
  • Cambs
  • Hahaha cool- 1000+bhp combined on the drive!!!!!!!
    • 3.0mv6 auto, cav4x4 turbo
Re: oil overfill
« Reply #12 on: 07 December 2011, 15:23:07 »
Think that's bad one of our machines at work has two oil fill points imagine the confusion people would face! The lower one MUST be a level plug???
The weather is here... Wish you were beautiful!
