Has anyone got a coolant level sensor for a 98 elite
Started by tnyquigs, 06 December 2011, 23:10:22
tnyquigs
Coolant level being displayed, when the level is ok.  I am assuming its the sensor.
sjc
fiend61
QuoteCoolant level being displayed, when the level is ok.  I am assuming its the sensor
get your finger in there (when cold)  :D and push float up and down a few times sometimes the float gets gunked up and stuck  :y  also check the electrical connections under the bottle  :y
Sensor is integral to the coolant bottle, they can be removed but often break!
Second hand is false economy, buy a brand new bottle from the dealer, around £35 on trade, are clear and look much better!  :y
MV6Matt
Quote from: fiend61 on 07 December 2011, 08:21:25
Just tried the finger waggling and found the electrical connection was completely detached - do you have to take the Air box/filter off to get underneath to put it back on?
I can't find enough room for fingers.
Any tips?
Matthew
(thanks Ian)
There is a metal clip which holds the header tank to the inner wing Matt.Prise that off then the tank can slide away from the inner wing giving more access.
sjc
Just remove the metal clip next to the wing and the header tank slides towards the engine before coming free - there should be enough slack in the water pipes to let you get to the bottom of it.
Far easier than removing the airbox!
Quote from: MV6Matt on 08 December 2011, 09:13:49
Any tips?
Matthew
Probably because the sensor is knackered ::)
MV6Matt
(thanks Ian)
MV6Matt
(thanks Ian)
