Author Topic: autobox  (Read 1196 times)
greenman
  • greenock
autobox
« on: 07 December 2011, 16:37:12 »
Looking for oil type and capacities for autobox ,02 2.2 facelift.
Re: autobox
« Reply #1 on: 07 December 2011, 16:40:16 »
The fluid is DEXRON IV (Fuchs Titan 4000 from Opie oils is the usual recommendation).
As to the capacity, total capacity is about 9 litres but if you change the fluid you will only get about 6 or 7 litres out, and therefore will only need 7 litres (to be safe) to refill.
greenman
  • greenock
Re: autobox
« Reply #2 on: 07 December 2011, 16:43:05 »
Thanks again.Any idea of price?
woodoo
  • Heanor
  • www.woodoo.yolasite.com
    • Vauxhall Omega 2.0l Auto
Re: autobox
« Reply #3 on: 07 December 2011, 17:18:06 »
Is it DEXRON IV? I have been told that I can use DEXTRON III and I did that. I used vacuum oil extractor to get fluid out, and it took only 4.5L. I had no time to change gaskets and filter so did quick fluid change. Latter I am thinking to do it properly  ;D So it would be great to know that fluid I should use. Anyway, fluid change and gearbox ECU update did a miracle to my Omega  :o
Re: autobox
« Reply #4 on: 07 December 2011, 17:22:17 »
DEXRON IV is the correct fluid, and I'm guessing you only drained the rear sump, hence less fluid was required.
I also take off the fluid cooler pipes and blow that through to remove any old fluid.
The recommendation for this type of box in older applications was Dex III, I believe, so I doubt it will do any harm.
Re: autobox
« Reply #5 on: 07 December 2011, 17:26:27 »
I only manage to get a gallon in my autobox when I did an ATF change, & I removed both sumps.  ;)
