Author Topic: A couple of quickies  (Read 1218 times)
Andys VXR
  • cambridgeshire
    • 3.2 Special
« on: 08 December 2011, 22:55:13 »
Hi just wondering what size the male torx bolts are on inlet manifold. Plus pedal trick dosnt work on my 03 manual 3.2 thanks Andy.
Re: A couple of quickies
« Reply #1 on: 08 December 2011, 23:10:07 »
Drive by wire issues can cause the pedal trick to fail. For instance if the throttle plug is left unconnected under the front of plenum.
What issues are you checking pedal trick for?
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #2 on: 08 December 2011, 23:23:13 »
I was just trying it as ive only had the car for two weeks just checking.
« Reply #3 on: 08 December 2011, 23:28:22 »
Does the relevant bulb light up with ignition on? Is it blown, or possibly removed....?
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #4 on: 08 December 2011, 23:34:50 »
its ok ive been a bit of a burke as i tried this while plenium was of so some plugs not connected.
« Reply #5 on: 08 December 2011, 23:45:38 »
 ;D its ok, thats sort of how i found out re dbw plug. Got the T shirt too.  ;D
