Pages: 1 [2] 3  All   Go Down
Author Topic: 2.5 TD doesn't want to know.  (Read 6219 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: 2.5 TD doesn't want to know.
« Reply #15 on: 10 December 2011, 16:26:42 »
neath.
if i was to bet the prob i would either say lack of fuel or air fault. could this be the fault?
Omegatoy
  • UK
« Reply #16 on: 10 December 2011, 19:24:53 »
classic lift pump problem by the sound of it, is it easier to start with a ful tank or at least over a quarter?
do a search on here lift pump blockage is well known! :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #17 on: 10 December 2011, 20:00:05 »
neath.
Right, so you're not far away!
Before going any further, how much fuel is there in the tank?
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #18 on: 11 December 2011, 14:26:13 »
between 1/4 and 1/2 of a tank
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #19 on: 11 December 2011, 15:47:13 »
Just went outside in the pouring rain, turned the key and it jumped into life.
Could it be something to do with the frosty weather.
Any ideas?
Seth
« Reply #20 on: 11 December 2011, 20:12:55 »
I'm inclined to suggest changing the glow plugs. ;)
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #21 on: 11 December 2011, 20:48:43 »
yes i think you could be right.
any idea of cost and which ones are best for the car.
Seth
« Reply #22 on: 11 December 2011, 20:56:14 »
I've fitted NGK's to the TDs that I maintain with no problems. Beru are also fine.
IIRC they were around 7 quid each.
Do you want me to get a price for them tomorrow?
Whatever you decide, do not fit the cheapo plugs that you find advertised on certain internet sites. >:(
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #23 on: 11 December 2011, 21:00:52 »
if you could mate.
cheers
Seth
« Reply #24 on: 12 December 2011, 13:55:12 »
PM sent ;)
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #25 on: 30 December 2011, 20:50:43 »
bloody car.
bought glow plugs. all set to replace.
had battery tested and looks like it could be that so took plugs back and got battery.
tried it and nothing. wont start.
took top plactic cover off and found a fuel line perrished so replaced and ............ still wont start
could it be anything else but glow plugs because it wont start at all now. >:(
Seth
« Reply #26 on: 30 December 2011, 21:21:20 »
As you've now got a brand-new battery, (so the engine's positively whizzing over), slacken one of the injector pipes at the injector end.
Get someone in the car, and try starting it, whilst you stand well back. You should see good squirts of fuel where you've slackened the injector pipe nut, as the engine's being cranked over.
PM sent ;)
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #27 on: 31 December 2011, 11:22:37 »
Have you done a compression test ?
Could also be its mechanical fuel pump
Seth
« Reply #28 on: 31 December 2011, 20:21:27 »
What for? - at this point (given the symptoms). :-\
Seth
« Reply #29 on: 31 December 2011, 20:23:57 »
Which pump are you referring too?
Pages: 1 [2] 3  All   Go Up
