Pages: [1] 2 3  All   Go Down
Author Topic: 2.5 TD doesn't want to know.  (Read 6180 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
« on: 10 December 2011, 09:55:43 »
Hi
Can anyone help me with some engine bay pictures of a pre-face lift diesel engine bay/ engine. The car itself has now got
starting problems. It may either be lack of fuel or broken/split vacuum pipes. So hopefully pics may help.
thanks
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Re: 2.5 TD doesn't want to know.
« Reply #1 on: 10 December 2011, 10:05:36 »
Does the cold weather effect the starting ?
starts alright when hot
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #2 on: 10 December 2011, 10:13:41 »
Well yes come to think about it.
Have fully charged battery overnight and this morning it tries , even shudders trying to start but alass lacks the final ooommmfff.
martin42
« Reply #3 on: 10 December 2011, 10:41:42 »
best thing to do is get a heavy duty battery,diesels use a lot of power in the winter months for starting,also check leak off pipes,common problem as this will cause air leaks.
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #4 on: 10 December 2011, 11:15:39 »
If it is difficult to start when cold  possible engine compressions
compressions need to be tight for a good cold start
possible heater plugs
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 10 December 2011, 11:24:48 »
How much Diesel is there in the tank?
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 10 December 2011, 11:26:10 »
I can send you pics of a 2.5 TD in a facelift, same layout. Have you replaced the Diesel Leak Off pipes?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 10 December 2011, 11:29:22 »
Good Battery essential this weather, check GP voltage past the relay, measure each GP individually to ground (1 or 2 ohms each), crank off one of the injector pipes, is it spitting diesel?
Worst case get some Cold Start in to the Air Intake, will sound like a bag of spanners going around in a washing machine but should start.
Chris.
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #8 on: 10 December 2011, 12:35:21 »
Easy start could knacker the engine if used regular
« Reply #9 on: 10 December 2011, 12:58:57 »
guessing these dont help ;D
(3rd post down on this page)
http://www.omegaowners.com/forum/index.php?topic=5860.435
crossy
  • Ireland
« Reply #10 on: 10 December 2011, 13:20:34 »
Hi
thanks
Used to happen mine a bit and what happened was the blank cap on the back injector was perished and letting out a mist(spray) of diesel. I couldnt actually see the diesel coming out with the covers on so I took the little cap off to check
Drive her straight sideways
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #11 on: 10 December 2011, 14:08:59 »
thanks for all the replys.
will try out this afternoon.
hopefully.
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #12 on: 10 December 2011, 14:10:43 »
at the front of the engine on the right hand side there is a silver cylinder with 2 pipe connections comming out. 1 seems to be fine, the other has nothing connected. any ideas as to why or is this a breather
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #13 on: 10 December 2011, 14:24:21 »
Sounds like it's the EGR valve - some have a pipe attached, which is connected to the inlet manifold.
Whereabouts are you?
« Reply #14 on: 10 December 2011, 16:09:50 »
Thats ok.
Pages: [1] 2 3  All   Go Up
