Author Topic: are drive shafts interchangeable  (Read 4278 times)
gary5661
« on: 10 December 2011, 23:09:56 »
just put in a different trailing arm in my car and it must have been off a different omega as the hub flange doesnt mate up mines a 2.0 16v if i was to get a drive shaft to match the hub will it work with my diff?
Re: are drive shafts interchangeable
« Reply #1 on: 11 December 2011, 14:08:52 »
I would have thought they were all the same,but Im not certain. :-\
« Reply #2 on: 11 December 2011, 15:27:37 »
4-pot are different to the V6 in that although the diff end are all the same, the bolt pattern to the hub differs (as the OP has found out)
« Last Edit: 11 December 2011, 15:32:58 by RobG »
gary5661
« Reply #3 on: 11 December 2011, 15:36:30 »
so all drive shafts are the same diff end?????
« Reply #4 on: 11 December 2011, 15:46:49 »
Yes
gary5661
« Reply #5 on: 11 December 2011, 15:50:29 »
right mines a 2.0 16v and my shaft doesnt mate up to the new radius arm that i fitted yesterday the stud pattern is different would you be able to suggest what shaft to go for as i really dont want to take the radius arm out again not sure what engine size omega the arm came out of
« Reply #6 on: 11 December 2011, 15:56:42 »
Seems like your arm is from a V6, so need a V6 driveshaft. Can you post up a pic of the hub end ideally with the PCD of the bolt holes
gary5661
« Reply #7 on: 11 December 2011, 16:02:34 »
the drive shaft holes on mine are closer together and on the hub there further apart about a mm also the size of the shaft is smaller than the hub, cant get pics camera broke soz
« Reply #8 on: 11 December 2011, 16:05:21 »
Here`s a pic of the V6 at the hub end. 6 holes each @ 50mm centres. Is this what your hub looks like
gary5661
« Reply #9 on: 11 December 2011, 16:11:43 »
yes it looks like that but on mine you can see the nut in the centre
« Reply #10 on: 11 December 2011, 16:20:10 »
Crossed wires Gary ;D The pic is of the actual driveshaft end that bolts to the hub. If your hub has the same pattern, this is the one that you need
gary5661
« Reply #11 on: 11 December 2011, 16:21:57 »
sorted so will any shaft over 2.5 fit this 3.0?
« Reply #12 on: 11 December 2011, 16:24:05 »
All V6 shafts are the same bolt pattern. I`ve got one here but postage on "next day" is a bit pricey. Can you source one locally?
gary5661
« Reply #13 on: 11 December 2011, 16:27:41 »
hopefully i live in newport and vauxplus is here, so ill ring them tomorrow see if they got one are these shafts just push and pull in the diff to get them out.
thanks ever so much for your help
« Reply #14 on: 11 December 2011, 16:31:35 »
Shame you weren`t nearer to Bristol. Decent jemmy bar between shaft and diff will release it, (if not get a garden spade in there for better leverage). Push-fit the replacement, make sure it goes past the circlip in the diff :y
