Author Topic: V6 coolant flush  (Read 1449 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
V6 coolant flush
« on: 11 December 2011, 10:38:37 »
As above
Cabin heater gives off very little heat when the revs are low and lpg take longer to cut in from cold.
Imo it time to give the coolant system a good flush out.
I know there is alot of cr*p in there so where is the best place to plug the hosepipe in and the best place to let it all out ?
hotel21
  • The Kingdom of Fife
Re: V6 coolant flush
« Reply #1 on: 11 December 2011, 10:42:28 »
I'm sure this has been asked a couple of times before.   ;)
Have a look in the maintenance guides.  Probably is a help in there......   :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 11 December 2011, 10:47:23 »
Found it  ::) :-[
Cheers H  :y
I_want_an_Omega
« Reply #3 on: 11 December 2011, 10:53:56 »
Hi Steve,
I've found that if you disconnect the plug in hoses that you can connect a hosepipe to the ends of the heater matrix. You will need to soften the end of the pipe with a hot air gun - which will allow it to form a nice tight fit with the pipe. Connect a 2nd short length of hose to the other pipe in the same way which will allow the output flow not to drench the engine bay/you.
Connect to a tap and then control the flow and watch the crud come flowing out. Then swap the connections over to reverse flow. Do this a couple of times and the jobs done.
Be careful not to use too much pressure/flow.
When you have finished the matrix will be full of water, so when you refill the system bear that in mind with the coolant mix to get the ratio correct.
HTH - Rob
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 11 December 2011, 10:58:28 »
Thanks Rob, i'll give it a try if / when it stops raining  :y
The electric arse warmers are working overtime at the moment, its bloody freezeing in there  ;D ;D
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #5 on: 11 December 2011, 23:44:39 »
I'd also recommend a few drops of fairy liquid in the header tank, cuts through all the grease and crud in there, works wonders, just make sure you get it all out
07 Volvo V70 T5 SE ex police
hotel21
« Reply #6 on: 11 December 2011, 23:48:49 »
Make sure its literally only a couple of drops otherwise its a bugger to cleanse properly.  Its use is as a grease cutter, not soapy suds, and there shouldn't really be much oil in there.........
« Reply #7 on: 12 December 2011, 00:06:16 »
Automatic washing machine liquid type stuff is better.Helps clean without all the bubbles. ;)
