Author Topic: Wireless Internet Problem  (Read 3144 times)
JiMbOb789
  • Timaru, New Zealand
    • x4 Omegas
« on: 05 March 2008, 16:48:36 »
Hello peeps, got a but of a problem. My son has internet upstairs and we bought him wireless internet. The router is called Netgear DG834GT and the wireless adapter that goes in the back of the laptop is a Netgear WG111T. The router workes on are downstairs computer but it doesnt work wireless.
I installed the program on the laptop and it only comes up for a second then goes again.
In device manager, it is an 'unauthorised device' but i dont know what to do.
Any advice?
Im on Vista by the way :y
http://kbserver.netgear.com/products/DG834GT.asp
http://kbserver.netgear.com/products/WG111T.asp
Re: Wireless Internet Problem
« Reply #1 on: 05 March 2008, 16:50:48 »
I don't know vista stuff at all .. but I'm guessing windows firewall blocking it ?? Can you try turning off all firewalls and see if it connects ?
Richie London
  • heathrow
« Reply #2 on: 05 March 2008, 16:53:07 »
is it password protected on your wireless, i have a password on mine to stop unuathorised access
supermop
  • Hoddesdon
  • User account problem.
« Reply #3 on: 05 March 2008, 16:53:26 »
Check your security encryption type. Some wireless adapters don't support the latest WPA 2 encryption protocols, and I've seen this behaivour before. It could also be because the router is not set to broadcast it's SSID.
- Log into the router
- Click on wireless settings
- Check the "Broadcast SSID" option is enabled
- Check that the encryption is set to WEP or WPA-PSK (WPA-PSK is the ideal choice).
JiMbOb789
    • x4 Omegas
« Reply #4 on: 05 March 2008, 17:03:43 »
hello, the firewall is off.
On the downstairs computer, the wireless internet works fine its just the laptop
supermop
  • Hoddesdon
« Reply #5 on: 05 March 2008, 19:10:00 »
Still handy to check the encryption type. As I mentioned, I've seen this exact behaivour from a friends laptop which was caused by an unsupported encryption type on the laptop's wireless card. Netgear router also.
Oh, and I wouldn't recommend leaving the firewall off unless you fancy becoming a new addition to a botnet  :P
« Last Edit: 05 March 2008, 19:18:44 by supermop »
« Reply #6 on: 05 March 2008, 19:18:40 »
netgear. 'nuf said.
supermop
  • Hoddesdon
« Reply #7 on: 05 March 2008, 19:19:11 »
netgear. 'nuf said.
what?! netgear are great home routers!!  :-?
Bandit127
« Reply #8 on: 05 March 2008, 19:19:27 »
I suspect this is to do with the wireless adapter you plugged in to the laptop, most likely the driver didn't load right.
2 things you can do - 1 easy, 1 not.
Easy - plug the laptop in using an ethernet (CAT5) cable. If you can get on the internet your problem is only with the wireless bit. Firewall is not the problem.
Harder - uninstall the driver for the wireless card (Google this until you know how). Make sure the driver software is Vista compatible. If you are unsure, download the right ones from the Netgear website. Re-load them taking care to put the card back in at the right point in the sequence. (Often after drivers are installed).
Keep us posted.
Jim
« Reply #9 on: 05 March 2008, 19:26:49 »
netgear. 'nuf said.
awful things.  piss poor 'firewall', unstable under heavy load, poor line-up times.  If you get a firmware that works for you, stick with it, as for every fix they implement, they break several more things.
Oh, and netgear are the reason several ntp servers shut down to internet a couple of years back, as some pillock at netgear decided to hardcode ntp servers into firmware, then make a mistake of setting the resync timer to 1 minute  :-?.  They fixed it in next firmware by using different ntp servers, but kept the 1m. Idiots.
Debs.
« Reply #10 on: 05 March 2008, 19:38:54 »
Those with Router issues may benefit from a visit to the guys at the Router Tech forum: friendly advice on all things 'Router' (Wireless, LAN, VoIP, Security, Encryp. etc.) and offers excellent firmware update downloads for the 'power-user'. :y
http://www.routertech.org/forum.php
JiMbOb789
    • x4 Omegas
« Reply #11 on: 06 March 2008, 08:04:59 »
thank you so much peeps, i really appreciate all the help. I just found out that netgear have been having problems with vista drivers for my router so i think is safer to go back to XP.
What do you think?
« Reply #12 on: 06 March 2008, 09:01:05 »
What do you think?
Well it wont be the netgear router that they are having trouble with as that wont have a driver, it will be the USB wifi dongle.
I have to say that I have found Netgear to be one of the best budget home routers by far....
« Reply #13 on: 06 March 2008, 09:08:38 »
What do you think?
I think changing the router will be more simple than changing the op.system and backing up all the files..
« Reply #14 on: 06 March 2008, 09:10:27 »
What do you think?
cem, its not the router, its the USB dongle thats the problem....
