Author Topic: Steering column...?  (Read 1508 times)
Steering column...?
« on: 13 December 2011, 16:32:04 »
Got a...(how to describe it)... A twang? Over bumps. Its like a resonance, as if twanging an elastic band when driving over bumps. Its always been there and changing suspension parts like bushes , wishbones, polly bushes, shocks and springs, drop links has had no inpact on it at all.
 But today i held the steering wheel under tension, by twisting it in my hands to take out any play, and the twang stopped over bumps.
What parts could affect this? Any exploded views of the steering column, or bushes that might need changing...? I can find no play in the steering linkages. Some wheel baring play, but this has come and gone, as i nipped it up, then returned again, but made no differance to this issue.
Ta
Re: Steering column...?
« Reply #1 on: 13 December 2011, 16:56:20 »
Ta
Any good
http://www.genmotorinfo.com/Picture.aspx?ccId=461290692&ppId=249288335&ppInfo=1997-2001+V%2cSteering+Column%2c-%26+Related+Parts+-+OV06007
« Last Edit: 13 December 2011, 16:58:41 by RobG »
« Reply #2 on: 13 December 2011, 17:47:01 »
Woo, well done Rob. :)
So, whats 15 at the bottom?
« Reply #4 on: 13 December 2011, 18:47:09 »
Hmm, so 15, 36/7 are possibles... ?
Also wonder if tightening the steering damper again might help  :-\
« Reply #5 on: 13 December 2011, 22:31:58 »
My money would be on the spring between 40 and 46 :-\ :y
« Reply #6 on: 13 December 2011, 22:40:04 »
Hmmm, need a dig around i think.
Good site that Rob. :)
« Reply #7 on: 13 December 2011, 22:51:26 »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #8 on: 13 December 2011, 23:11:37 »
hmmm very good site rob ;)
going back to one of my original posts what in that lot could creak when turning steering wheel ??
no15 is that a bearing?
« Last Edit: 13 December 2011, 23:15:12 by fiend61 »
« Reply #9 on: 14 December 2011, 08:44:37 »
Yep
« Reply #10 on: 14 December 2011, 15:06:38 »
The spring behind the wheel (with no number). Might be worth pulling the wheel off and checking each part for undue wear/damage/play :-\
Twas the week before Christmas... :y
