Author Topic: cam pulley bolts and thermostat.  (Read 1180 times)
tidla
  • solihull
« on: 13 December 2011, 17:14:13 »
are the cam pulley bolts to camshaft stretch bolts or reusable?
is the thermostat available on its own or only with the 90o housing?
thanks
Andys VXR
  • cambridgeshire
    • 3.2 Special
Re: cam pulley bolts and thermostat.
« Reply #1 on: 13 December 2011, 17:25:17 »
Finished my stat today and it came with the housing. Even if you can get stat on its own the work you have to do is the same so you might as well get it with housing only cost me £33.00 plus i changed the O rings on transfer pipe 67p
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 13 December 2011, 21:04:57 »
where was that from stealers? tc ?
sorry about the questions but i am in the process of pricing one up  ;)
tidla
  • solihull
« Reply #3 on: 13 December 2011, 21:07:26 »
asked the same question at the dealers today , retail cost £45 plus vat. thermo and housing.
tidla
  • solihull
« Reply #4 on: 13 December 2011, 21:09:43 »
(on my vehicle the housing and slide tube are still intact and at the moment can be installed this way.)
« Reply #5 on: 13 December 2011, 21:29:07 »
Cam pulley bolts are stretch bolts, IIRC, but are commonly reused without issue.
Thermostat normally comes with housing. Thee are cheaper parts on Ebay but beware the housings can vary so the bolts might need to be shortened or replaced with longer and the seal is also different so make sure you get one with the housing.
You'll also need the 2 transfer pipe O rings.
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #6 on: 13 December 2011, 21:36:21 »
I just got mine from a local shop i phoned around first and when i got it i checked all the things in the above post
Page created in 0.028 seconds with 16 queries.
