Author Topic: Headlamp Warning Light.  (Read 1590 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 15 December 2011, 11:43:37 »
Good morning everyone  :)
My orange light has been on for a while now, speaking to Twigglet a while ago about it he said it would be the ECU that was the issue and that he had one, so i bought it.
Finally fitted it this morning after struggling to find where it was hidden and guess what?  The light is still on! Doh! :-X
Has anyone any further ideas as to what the problem could be?
Re: Headlamp Warning Light.
« Reply #1 on: 15 December 2011, 12:09:36 »
Have you checked the level sensors front and back :-\ The arms can pop off, simple fix and obvious if they're the problem :y
P6UL K
  • Dartford, Kent
« Reply #2 on: 15 December 2011, 12:16:06 »
Are they the drop link arms?  Wheres the rear one, front is N/S IIRC?
« Reply #3 on: 15 December 2011, 12:23:43 »
Both near side. The O/S one at the back is for the self levelling suspension.  :y
There is also a separate ECU for the Xenons in the O/S front wing :-\
P6UL K
  • Dartford, Kent
« Reply #4 on: 15 December 2011, 12:28:54 »
Cheers for that... Did you read my first post? lol  :P  Theres a link there also to my original post 'ECU'
P6UL K
  • Dartford, Kent
« Reply #5 on: 18 December 2011, 22:52:30 »
Both front and rear droplinks are all ok and the ecu has been replaced, but the light on the dash is still alight....
Any further ideas as to what the problam could be?
« Reply #6 on: 18 December 2011, 23:27:42 »
Duff adjuster motor or duff sensor perhaps :-\ Any fault codes :-\ Tech 2 session may be able to pinpoint exact busted component. Not alot else to suggest if it's put the light on, obviously summat amiss. :y
P6UL K
  • Dartford, Kent
« Reply #7 on: 19 December 2011, 06:08:39 »
Cheers Al, i'm currently on the hunt for a local Vx dealership that might be able to read my ECU for a Christmas tip, failing that someone from here thats not to far away from me.
« Reply #8 on: 19 December 2011, 08:11:38 »
You could try switching the lights on (engine off) then jack the front of the car so the wheels are off the ground. This ought to trick the system into adjusting the lights and you'll hear the motors working, assuming of course that they do ::). As a thought, have you changed the headlight switch? Should be front/rear fogs and dash light dimmer, if one is fitted that has the range control on it, that could be the problem :-\
P6UL K
  • Dartford, Kent
« Reply #9 on: 22 December 2011, 11:34:29 »
Looks like i may be seeing light at the end of the tunnel!  Had the car on a Vauxhall ECU read (non-Tech2) and its pin pointed the issue!  I hope lol  ::)
"Rear height level sensor"
Off to the parts wanted section i go...........  :y
« Reply #10 on: 22 December 2011, 13:50:39 »
Result :y hopefully that'll sort it :)
