Author Topic: abs ecu's  (Read 1192 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
abs ecu's
« on: 16 December 2011, 16:40:08 »
Any difference in the software settings between a 2.5 and a 3ltr manual ?
Mine still has a 2.5 abs system fitted but a 3ltr engine.
I have noticed that abs tends to kick in on the front wheels rather easy ?
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: abs ecu's
« Reply #1 on: 16 December 2011, 16:44:49 »
have you had on tec 2 wile driving see what the abs unit is doing?
Solar charger fitted.
If not Broke dont fix it..
Re: abs ecu's
« Reply #2 on: 16 December 2011, 16:46:48 »
Yes, there is a setting on the ABS ECUs for engine type, I believe. I wouldn't expect it to affect ABS functionality greatly. It's more likely to be to tune the traction control torque reduce to suit the engine size.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: abs ecu's
« Reply #3 on: 16 December 2011, 18:29:19 »
No
It was just something that has been bugging me for a while  :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: abs ecu's
« Reply #4 on: 16 December 2011, 18:36:34 »
I have noticed that the Tc is reluctant to play sometimes.
You can get the wheels to spin up a little (pulling out of a wet junction) before it cuts in on one day.
Another day, you can just touch the brake pedal and the abs will kick in  :-\
Not a real problem, just one of those things that bugs me.
Bit like me really  ;D ;D
