Author Topic: Battery drain on 2.5TD  (Read 2551 times)
mc9
  • Luton, Beds
« on: 16 December 2011, 20:20:12 »
Just had a diagnostic check on the car. No fault codes found but the tester did find a parasitic battery drain of 0.35 amps. He suggested that an electronic time delay module failing to turn off might be the problem. The courtesy lights do go off as expected but can the electronic timer module remain active and cause a current drain?
Anyone seen a problem like this? Any fixes?
Thanks
mc9
Re: Battery drain on 2.5TD
« Reply #1 on: 16 December 2011, 20:34:32 »
Sadly, it'll be a process of tedious elimination :(
tidla
  • solihull
« Reply #2 on: 16 December 2011, 20:50:57 »
you can get a cheapo amp meter from (maplins) which fits in the place of the fuse, thus showing which circuit the drain is occuring :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 17 December 2011, 09:47:24 »
Tried unplugging the powersounder ?
Radio & Decoding Technician
www.dndservices.co.uk
mc9
  • Luton, Beds
« Reply #4 on: 17 December 2011, 17:37:28 »
It's a "der" moment. One of the rear courtesy lights was on continuously. It's so dim (don't say a word) that nobody noticed, even at night. Not even the two auto-electricians who examined the car.
12V x 0.38A = 4.6W, sounds about right.
Goes to show -- always check the OBVIOUS first  :-[
Cheers
mc9
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 17 December 2011, 17:48:18 »
Glad you are sorted !!
Don`t worry, you are not the first, and you wont be the last with that one !!
 :-X
tidla
  • solihull
« Reply #6 on: 23 December 2011, 17:53:16 »
illuminating info.... no. ill get my coat.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #7 on: 23 December 2011, 17:57:37 »
know this sounds crazy and you may of checked but is boot light going off, seen it so many times on days of doing work for the aa
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
