Author Topic: clutch help, please!  (Read 1064 times)
spurgindavid
  • Essex
    • V6 omega
« on: 17 December 2011, 07:54:04 »
right so the car is nearly starting now, getting  a new sensor within the hour which should solve that problem...
however the clutch is right to the floor, pull it up, it stays in place
slight touch on the pedal and it goes straight down to the floor where it stays  ::)
im guessing this is because there is no resistance and it may need bleeding? but how?
all replies are appreciated
many thanks d
RobseyMV6
  • west sussex
Re: clutch help, please!
« Reply #1 on: 17 December 2011, 08:33:56 »
Hi D, easy way to do this by yourself is to buy a Clutch/bale bleeding kit from halfords around £20 very very easy to use, just read up on box, undo nipple on gearbox with clear pipe conneted and repeat till you see no more air bubbles  :y
spurgindavid
  • Essex
    • V6 omega
« Reply #2 on: 17 December 2011, 08:39:17 »
Cheers
This whole engine change has been bit of a nightmare the boy is on his way now to meet another member to borrow a new crank shaft sensor.Engine just wont fire dont spose u got any ideas?
RobseyMV6
  • west sussex
« Reply #3 on: 17 December 2011, 08:46:01 »
Well silly as it may sound i did a head gasket in a 3.2 and removed loom before and forgot to plug the fuse back in over top the car battery that runs ecu i think, so my one just turned over and over but no fire, only way i noticed with no fuse no EML light on inside car when lights up after turning key. might this be your problem?  ;) ;)
spurgindavid
  • Essex
    • V6 omega
« Reply #4 on: 17 December 2011, 08:51:45 »
Hi
Yeah we all do silly things,ha. But all the lights come on and I have done the paper clip test and it comes up with code 31, which I am reliably informed means crank shaft sensor is buggered? Hope this is the case as suppose to be in Norfolk now at a drift meet :( But thanks for your help must say how good and friendly people are on this forum! ;D
« Reply #5 on: 17 December 2011, 10:00:18 »
Bleed the clutch back to front ie pump the fluid in through the nipple ;)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #6 on: 17 December 2011, 10:38:14 »
was it alright before, should not just go like that,
Solar charger fitted.
If not Broke dont fix it..
