Author Topic: High idle and hunting  (Read 4644 times)
Debs.
Re: High idle and hunting
« Reply #15 on: 20 December 2011, 10:29:57 »
Temp sensor behind bumper on the blink :-\
 :-\ Erm......is not the intake-air temperature sensor located in the area around the MAF?.....I thought the under-bumper one was just for the display?.....I might be wrong, though. :-[
Having recently suffered faulty crank-sensor woes, I also noted that the various symptoms (no/low/oddly-high/hunting idle) were considerably worse on cold mornings; might this perhaps, be warning of a failing crank sensor?
« Reply #16 on: 20 December 2011, 10:41:13 »
No indeed, engine temp is taken from the spade connector to brass coolant sensor on the coolant bridge under plenum. These can corrode /fall off.
But check for minor air leaks, such as loose icv to plenum, breather pipes ect.
« Reply #17 on: 20 December 2011, 11:07:02 »
Intake air temperature is indeed a separate sensor near the MAF on pre-DBW V6s. On DBW V6s, it's built into the MAF sensor itself.
GaryBC
  • Egham, Surrey
« Reply #18 on: 20 December 2011, 11:09:43 »
The indicated outside temp display on the dash seems ok - does the engine management computer take a feed from there too?
Where is it? If it's easy to get at I can re-seat the connector.
No. ;)
Not a lot of point fiddling with it then! But it begs the next (obvious?) question of, "so where does the engine controller get it's temp feeds from - specifically the engine temp (as opposed to ambient)?" The way I figure it it is this feed that is probably causing the problem as the high and erratic idle suggests it thinks it is still stone cold. (Although I know that nothing on a Miggy is ever as simple as that!!)
GaryBC
  • Egham, Surrey
« Reply #19 on: 20 December 2011, 11:17:59 »
The second point sounds like my best initial bet. If the connector came adrift the problem wouldn't have corrected itself. (Mind you - thinking about it - neither would an air leak spontaneously fix itself either!) Could a failed (or failing) temp sensor be the cause of my problem?
Debs.
« Reply #20 on: 20 December 2011, 11:19:18 »
I believe I remember seeing an engine fault code for 'coolant temperature voltage high/low' :-\
Have you "paperclipped" for any codes?
http://www.omegaowners.com/forum/index.php?topic=90524.0
« Last Edit: 20 December 2011, 11:31:29 by Debs. »
« Reply #21 on: 20 December 2011, 20:37:00 »
No. ;)
New thing learnt :y
