Author Topic: Suspension problem  (Read 3093 times)
Suspension problem
« on: 19 December 2011, 12:07:00 »
Went over a pothole today, and was then met with a nasty clunk and rattling from the back of the car.
Nothing to see underneath...
Checked the shock mounting points, and the passenger side rear upper shock mount was dented :y
The amount of shock absorber poking though seems far too much..
other side for comparrison
Inside I have these parts,
underneath I have this,
which looking on the guides here, and EPC, I dont seem to be missing anything  ???
Whats gone wrong?  how do I fix it?
formost in my mind is the shock 'threaded bar part' has pulled out from the main shock and is now too long?  is this even possible?
Shocks are 18 months old, genuine GM MV6 ones.
HELP!!!!
(ive had a clunk, I think from the front of the car for some time, which may, or may not be related)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: Suspension problem
« Reply #1 on: 19 December 2011, 12:22:10 »
looks like its missing a collar off the lower part that should stop it pushing up through the rubber mount
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #2 on: 19 December 2011, 12:25:57 »
Whatever acts as a stop at the bottom of the threaded section has opened up/fell off/gone missing ???
adey2
« Reply #3 on: 19 December 2011, 12:29:05 »
normally a big washer albs, i just been looking at the self leveling set i have in garage for a saloon and it fits on the lip you an see
« Reply #4 on: 19 December 2011, 12:32:38 »
but I cant see what that should be from epc
« Last Edit: 19 December 2011, 12:34:59 by Jimbob »
« Reply #5 on: 19 December 2011, 12:35:58 »
Have you looked at the aperture in the floor James,to see if the shock has been pushed up through it ?
Lower washer No.6 - cant see it in your pic. :-\
« Last Edit: 19 December 2011, 12:38:26 by Albs »
adey2
« Reply #6 on: 19 December 2011, 12:36:58 »
from your pics of bits i can only see one of the 2 no6 washers, the bottom one is missing allowing the top of strut to push up through the rubber
« Reply #7 on: 19 December 2011, 12:38:36 »
yes, top of 8/9 sits snugglly in the opening....but with loads of 'bar' not just the threaded end.
Hmmmmm maybe 6 I am missing, should that sit at the very start of the threaded section?  That looks like it could be it?
« Reply #8 on: 19 December 2011, 12:41:01 »
Whoever changed the shock at some point has ommited the big washer,and hitting a big bump has allowed the rubber bush to be pushed up into the inside of the car.
Worth having a look at the order of assembly on the other side ?
« Last Edit: 19 December 2011, 12:43:15 by Albs »
adey2
« Reply #9 on: 19 December 2011, 12:41:53 »
looks like trip to local breakers for you to find said washer
« Reply #10 on: 19 December 2011, 12:43:23 »
one is on order at VX....due in in the morning at £1.44
adey2
« Reply #11 on: 19 December 2011, 12:44:37 »
id be checking that the other side is fitted too, or you could find that you end up with same problem in near future
« Reply #12 on: 19 December 2011, 12:52:24 »
just had another check, that is definatley missing, wonder where it has gone?
other side sitting perfectly.
adey2
« Reply #13 on: 19 December 2011, 12:59:45 »
ok buddy, im up your way on weds or thurs, coming to deeside to pick a engine up for my missis lpg vectra. give my miggie a chance to stretch its legs up the m6
« Reply #14 on: 19 December 2011, 13:07:10 »
Cant see how it can go anywhere.Someone has forgotten to fit it imo.Wonder how long its been like that ? Could have been dangerous. ;)
