Author Topic: autobox gear ratios...  (Read 1534 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 21 December 2011, 23:32:13 »
is there any difference in ratios between the AR25 and AR35?
alex
V8!!!!
Re: autobox gear ratios...
« Reply #1 on: 21 December 2011, 23:56:58 »
Short answer, dunno!
Longer answer, would think same, given how the dif ratios react between the two.
Ineresting. Though.
ngrainqey
  • rotherham
« Reply #2 on: 22 December 2011, 12:53:34 »
i started wondering last night when i saw my ar35 that'd turned up on a pallet: is there a difference in ratios? Are the TC's the same between ar25 and 35 and what makes the 35 able to take more torque? Why not fit just ar35's on omegas, they'd only ever need the 35 for the entire range
V8!!!!
« Reply #3 on: 22 December 2011, 13:20:47 »
I seem to recall the Ar35 being slightly longer geared than the AR25 (from memory based on fitting AR35's into TD's).
The extra strength is due to the extra clutch plates within the box.
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 22 December 2011, 13:38:17 »
but extra plates are olny on 2nd gear in ar 35
ngrainqey
  • rotherham
« Reply #5 on: 23 December 2011, 17:16:12 »
thanks for the replies, in theory then only 2nd gear is more robust :/ still don't get where the 100nm comes from
V8!!!!
« Reply #6 on: 23 December 2011, 17:58:54 »
http://www.omegaowners.com/forum/index.php?topic=90453.0
This would suggest that the 4 pots have different ratios. Not sure about the shorter 1st on 2.6 MV6/Elite. Looks like a typo to me.
