Author Topic: idle speed  (Read 1066 times)
tidla
  • solihull
idle speed
« on: 23 December 2011, 00:29:31 »
recently had to sort a water leak due to the reducing temperatures which turned out to be the oil cooler plate, while in there i redone the thermostat, cambelt timing and rocker covers.
before the work the idle was a dead 500rpm with the rise for aircon, repaired a couple of breather hoses which had splits, and the egr to plenum seal.
plenum been off twice(dont ask) air pipes seem intact.
on idle in gear is 600rpm, in neutral it bounces up to 750 rpm,
do the injector seals give trouble?
once warm does the icv valve close fully or still have an influence?
breather system ok.
thanks
Re: idle speed
« Reply #1 on: 23 December 2011, 00:54:07 »
Which motor mate - V6 usually runs 500-550rpm without a/con on & 600-650rpm with a/con on.  Try cleaning ICV with carb cleaner and relubricating with light oil (3in1)
Me
  • Doghouse
  • It was Guffer's fault
Re: idle speed
« Reply #2 on: 23 December 2011, 15:23:03 »
Initial reaction is an air leak somewhere...  ...though cleaning ICV is worthwhile 1st step...
"Always look on the bright side of Life"
TheNaughtyBoy
tidla
  • solihull
Re: idle speed
« Reply #3 on: 23 December 2011, 17:50:04 »
disappearing profile detail updated.
icv clean it is, thanks
